But if reversing cameras are banned then what are the 3T trucks with no windows gonna do?
And what are the panel beaters gonna do when Suzy learns how to park properly? Or Shane finally gets used to how close his garage door really is?
You gotta think of the future GTSBoy
I am thinking about the future.  I'm thinking of a future where everybody looks like the meat pillows in the Wall-E movie.  They're almost there now.  Can't do a google search without having Siri or Alexa stand between you and the nasty internet to handle your query.  Can't buy anything if it involves using a phone as a voice communication device - has to be on-line.  Can't navigate the roads of their own city without eyes glued to the blue line on the phone screen at eye level above the dashboard.  Can't cook, have to use Uber-eats.  Can't reverse a car without beepy sensors or screens showing alignment lines, or worse, auto f**king self parking faggotry.
/rant
Every time I hire a car it takes about a week before I notice that the thing even turns a camera on and shows a blurry f**ked out view of what's behind me when I engage reverse gear.  That's because  I'm already doing the right thing by looking backward before I engage reverse to make sure there's nothing behind me.
This isn't a disucssion about the need for reversing cameras (they have been legislated in the US to be on every passenger car from 2018 on.)
https://www.autotrader.com/car-news/new-backup-camera-rule-cameras-will-be-mandatory-by-2018-223739
As for the post you quoted, it no longer exists. :(
  • Like 1
I've seen several options on the market for R34 that replace the rear license plate light, so that it works/looks relatively OEM.
I've been trying to source one for a while, but the only ones I've tracked down don't have any side marker lines on the image  - which is something that's overlayed in the camera.
In the past, I'm fairly sure that Carbon Car Systems and Chris Rogers have been able to supply similar, along with MFD integration if required (not relevant to GTT)
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
