https://www.facebook.com/events/144367356234846/
== SUCC MOTORSPORT DRIFT CAMP 2018 ==
=> The Run Down <=
March 24/25 (Camping from the 23rd)
2 Days of Drifting, Tandems, Passengers, Competitions
Coaches, 100% Beginner Friendly
Camping included in the event cost
Meals included in the event cost
=> Pricing <=
The event is $239 for both days, camping and food costs
$50 discount for those who have paid for UTAC 2018
=> Event Specifics <=
Wilby Motorsport Park
Awesome track out near Yarawonga, see attached videos for details!
=> SUPP REGS <=
Edited by Pr0x1mity
  • Like 1
I hope so! We want to try run more events like this one (We hold the track license for Wilby) in the future! Its cheap as f**k, don't have to worry about acom or dinner sat night etc and we're not compromising by having 80 spots. Limited spots available!
Hopefully we get some SAU guys on board so I'm not the only Skyline there (Doubt I will beeeee!)
If you have any questions shoot me a PM or ask in here!
At the moment on the event page we're looking at running a few little fun comps for the sunday.
Here's a video from the track :)
Still limited spots left, once thats done we'll take a waiting list.
-Cheap!
-2 days of drifting + CAMPING AND FOOD INC!
-CAPPED ENTRIES @ 40
-Max track time
-No bullshit
-Beginner to pro friendly
-YTB
-Get on it
  • 1 month later...
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
