The ECUTEK has RACEROM, the rev match is enabled (I am really bad at heel toe) this does it for you.
Also has flat foot shifting enabled ( ECUTEK uses both fuel cut and ignition retard working together), if it was just fuel cut I wouldnt use it, I like my pistons, if it was just ignition I wouldn't use it as I like my turbo.
It has launch control, but this feature has never been enabled.
I may be interested in a mint original AUD S15 with cash my way.
Minor mods are good but......
Disclaimer: No pi gs, no respays, no 400hp fully dayglow spec with body kits, no prior accident repairs.
I will have it checked out with a fine tooth comb.
I have been looking around lately at S15's, I want a good one though, and by good I mean mint, the better the car the less cash my way.
Example: I missed out one 2 years ago, it had 4k original km on it and it sold for 28k.
Both cars will end up at a local shop for inspection, Pulse Racing is close to me.
  • 3 weeks later...
On 5/14/2018 at 2:25 PM, The Panda said:
If you are looking for a p-plater fun weekend car - I have an AP1 S2000... 4.44 diff and some other fun stuff. I need a more work appropriate car :(
Shoot me a email with some more info and pics mate. How much do you think the S2000 is worth realistically.
Thanks for the email
Your car looks sweet but sadly not what I am after.
I wish you luck with your sale.
Cheers
  • 4 weeks later...
Keen to hear your thoughts on the 86, coming from the STI, by the looks you got the limited ed. ver with the brembos, sachs and updated diff?
Really liking these at the moment, just finding it hard to find $30K from the back of the sofa.
So far so good, I replaced the Michelins with some RS4's today, should be good once they are scrubbed in, I had some RS3's on my MX5 and liked them alot.
In the couple of days I've had it I'm loving it, even with the crappy Michelins it was a hoot, it's good to be back in a light(ish) RWD platform.
Power wise it wouldn't pull the skin of custard, but that not the point of it, or why I got it.
Wringing its neck, throwing it into a corner, playing with some oversteer is so much fun.
I also grabbed a cat back for it, a XForce 2.5" jobbie, sounds alot better, well you can hear it now anyway, with the stock cat back I couldn't even hear the exhaust, I estimate the power increase from the cat back is an astonishing 0%.
So, for future mods, some alignment bolts from whiteline are on the cards, stock camber adjustments are non existent, apart from toe, stock camber is 0.0 deg, I'm going to hammer some corners and see what the tyres are saying and dial some in from there.
Cheers
  • Like 1
On 7/3/2018 at 9:31 AM, JGTC said:
Awesome, good to hear Mark, i totally agree with you on that simple layout is best as i get older, more fun at less speed with less to go wrong.
Camber bolts only gave me -0.5 with them maxed out, rears are -1.3 L and 0.97 R (not adjustable).
I'll try some 14mm lower camber bolts for the front and see where that puts it, if all else fails I will grab some strut tops as well, I will grab some adjustable arms for the rear.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
