The ECUTEK has RACEROM, the rev match is enabled (I am really bad at heel toe) this does it for you.
Also has flat foot shifting enabled ( ECUTEK uses both fuel cut and ignition retard working together), if it was just fuel cut I wouldnt use it, I like my pistons, if it was just ignition I wouldn't use it as I like my turbo.
It has launch control, but this feature has never been enabled.
I may be interested in a mint original AUD S15 with cash my way.
Minor mods are good but......
Disclaimer: No pi gs, no respays, no 400hp fully dayglow spec with body kits, no prior accident repairs.
I will have it checked out with a fine tooth comb.
I have been looking around lately at S15's, I want a good one though, and by good I mean mint, the better the car the less cash my way.
Example: I missed out one 2 years ago, it had 4k original km on it and it sold for 28k.
Both cars will end up at a local shop for inspection, Pulse Racing is close to me.
  • 3 weeks later...
On 5/14/2018 at 2:25 PM, The Panda said:
If you are looking for a p-plater fun weekend car - I have an AP1 S2000... 4.44 diff and some other fun stuff. I need a more work appropriate car :(
Shoot me a email with some more info and pics mate. How much do you think the S2000 is worth realistically.
Thanks for the email
Your car looks sweet but sadly not what I am after.
I wish you luck with your sale.
Cheers
  • 4 weeks later...
Keen to hear your thoughts on the 86, coming from the STI, by the looks you got the limited ed. ver with the brembos, sachs and updated diff?
Really liking these at the moment, just finding it hard to find $30K from the back of the sofa.
So far so good, I replaced the Michelins with some RS4's today, should be good once they are scrubbed in, I had some RS3's on my MX5 and liked them alot.
In the couple of days I've had it I'm loving it, even with the crappy Michelins it was a hoot, it's good to be back in a light(ish) RWD platform.
Power wise it wouldn't pull the skin of custard, but that not the point of it, or why I got it.
Wringing its neck, throwing it into a corner, playing with some oversteer is so much fun.
I also grabbed a cat back for it, a XForce 2.5" jobbie, sounds alot better, well you can hear it now anyway, with the stock cat back I couldn't even hear the exhaust, I estimate the power increase from the cat back is an astonishing 0%.
So, for future mods, some alignment bolts from whiteline are on the cards, stock camber adjustments are non existent, apart from toe, stock camber is 0.0 deg, I'm going to hammer some corners and see what the tyres are saying and dial some in from there.
Cheers
  • Like 1
On 7/3/2018 at 9:31 AM, JGTC said:
Awesome, good to hear Mark, i totally agree with you on that simple layout is best as i get older, more fun at less speed with less to go wrong.
Camber bolts only gave me -0.5 with them maxed out, rears are -1.3 L and 0.97 R (not adjustable).
I'll try some 14mm lower camber bolts for the front and see where that puts it, if all else fails I will grab some strut tops as well, I will grab some adjustable arms for the rear.
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
