The ECUTEK has RACEROM, the rev match is enabled (I am really bad at heel toe) this does it for you.
Also has flat foot shifting enabled ( ECUTEK uses both fuel cut and ignition retard working together), if it was just fuel cut I wouldnt use it, I like my pistons, if it was just ignition I wouldn't use it as I like my turbo.
It has launch control, but this feature has never been enabled.
I may be interested in a mint original AUD S15 with cash my way.
Minor mods are good but......
Disclaimer: No pi gs, no respays, no 400hp fully dayglow spec with body kits, no prior accident repairs.
I will have it checked out with a fine tooth comb.
I have been looking around lately at S15's, I want a good one though, and by good I mean mint, the better the car the less cash my way.
Example: I missed out one 2 years ago, it had 4k original km on it and it sold for 28k.
Both cars will end up at a local shop for inspection, Pulse Racing is close to me.
  • 3 weeks later...
On 5/14/2018 at 2:25 PM, The Panda said:
If you are looking for a p-plater fun weekend car - I have an AP1 S2000... 4.44 diff and some other fun stuff. I need a more work appropriate car :(
Shoot me a email with some more info and pics mate. How much do you think the S2000 is worth realistically.
Thanks for the email
Your car looks sweet but sadly not what I am after.
I wish you luck with your sale.
Cheers
  • 4 weeks later...
Keen to hear your thoughts on the 86, coming from the STI, by the looks you got the limited ed. ver with the brembos, sachs and updated diff?
Really liking these at the moment, just finding it hard to find $30K from the back of the sofa.
So far so good, I replaced the Michelins with some RS4's today, should be good once they are scrubbed in, I had some RS3's on my MX5 and liked them alot.
In the couple of days I've had it I'm loving it, even with the crappy Michelins it was a hoot, it's good to be back in a light(ish) RWD platform.
Power wise it wouldn't pull the skin of custard, but that not the point of it, or why I got it.
Wringing its neck, throwing it into a corner, playing with some oversteer is so much fun.
I also grabbed a cat back for it, a XForce 2.5" jobbie, sounds alot better, well you can hear it now anyway, with the stock cat back I couldn't even hear the exhaust, I estimate the power increase from the cat back is an astonishing 0%.
So, for future mods, some alignment bolts from whiteline are on the cards, stock camber adjustments are non existent, apart from toe, stock camber is 0.0 deg, I'm going to hammer some corners and see what the tyres are saying and dial some in from there.
Cheers
  • Like 1
On 7/3/2018 at 9:31 AM, JGTC said:
Awesome, good to hear Mark, i totally agree with you on that simple layout is best as i get older, more fun at less speed with less to go wrong.
Camber bolts only gave me -0.5 with them maxed out, rears are -1.3 L and 0.97 R (not adjustable).
I'll try some 14mm lower camber bolts for the front and see where that puts it, if all else fails I will grab some strut tops as well, I will grab some adjustable arms for the rear.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
