Hi Richard,
My 2c is that seeing as I have never seen an external proportioning valve on a Nissan of the R3x era....then you'd expect all the BM44/50/57 type MCs to have prop valves inside.
As to how to remove it so that the MC keeps working......dunno.  I have heard tales of people removing the prop valve and having the pedal go to the floor because removing it makes the back half not work properly.  Dunno if there was a better way for such people to do it than what they did, and I've not played with it myself.
Have a look at this thread off SAU here, for some clues (not clues that answer all your questions, but clues nonetheless)
  • Thanks 1
Pretty sure that a Patrol has a one and 1/16" BMC so the one I have may not have a prop valve. Shouldn't be too hard to remove the piston and see what if anything is behind it.
OK to wrap this up (if it all works lol)  I got a  Patrol JB1775 MC which has only two outlets and no prop valve. The GTR one I have has a non removable prop valve and is specced for the Brembo front caliper models so it's no good for me and is for sale.
I would be inclined to give the GTR M/C a go. "Specced for the Brembos" sounds more scientific than it probably is. I used a GTR M/C on my AWD Stagea with 330mm brakes on the front and 2 pot GTR calipers on the rear  and it pulled up fine at any speed. Incidentally when I rebuilt the M/C it was with a ZX kit.
The Patrol MC is the same size, it just doesn't have a inbuilt prop valve which is what is not wanted when a separate adjustable prop valve is used.
Edited by 260DET
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
