hey all just got my first skyline. as the title says its a 94 R33 GTS25T .
i swapped it for a un finished AE86 project,
it came regoed and slightly modified, and not very well looked after.
so far the mods i know of are:
  • Front Mouint
  • High flowed stock turbo (hypergear?) internal gate welded shut and actuator disconnected
  • 50mm external wastegate and screamer
  • turbosmart e-boost street boost controller
  • turbosmart boost gauge
  • AFR gauge of some sort
  • unknown brand fuel pressure regulator
  • cut and shut forward facing stock intake manifold
  • 3" exhaust
  • maxpeeding coilovers
  • exedy HD clutch
  • 18x9.5 Work Emotion Kiwami's (metallic charcoal)
she definitley needs some tlc and a heap of bugs need to be looked at but it seems pretty strong and goes well. looking forward to keeping this thread updated as i progress.
 28164270_1973980405964904_4077533710549516909_o.thumb.jpg.1c3a1b1bd1fb0790b2979de063b8e740.jpg28161900_1973981095964835_1912114468415340601_o.thumb.jpg.f1ac23b132ef1ff05edfd9fe3a698759.jpg
27973357_10156125851136100_6759519495438240161_n.jpg.0146b023dc98180ab872394e5e8998f6.jpg
  • Like 1
https://www.sau.com.au/forums/topic/473357-wrightys-1994-r33-gts25t/
  • 4 weeks later...
  • 10 months later...
Dug the rice line out over the long weekend...New bov charged the battery give it a wash  found the leak in my rim.. put her back in the shed haha almost ready for rego again...
also since last time i was on here i have . replaced pod with factory air box, changed to led headlights, replaced drivers window reg, fitted a different steering wheel , 3d printed and mounted gauges, new head unit and mounted subs/amps
  • Like 1
  • 3 weeks later...
  • 1 month later...
Did a thing today .. after fitting and replacing some shit. (Uncut front bar and other random interior bits and mounting my stereo and gauges) give her a bath and went for a lap.
Now just need : hicas eliminator, wheel alignment, ecu, tune and rego
  • Like 1
  • 1 month later...
  • 2 months later...
time for an update....its been a little while.
She now has :
  • R35 GTR coils
  • 600cc injectors
  • haltech elite plugin ecu.
  • Extreme Ceramic Button clutch
Got it dynoed with DVS Tuning and it made 220rwkw on 12psi and 236rwkw on 18psi
can't fault jez's work he's a champion and i cant thank him enough
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
