On 21/08/2019 at 11:57 PM, Milkmun said:
6psi extra for only a gain for 16rwkw?
More like 2psi up top, his actuator is weak hence his gate is being blown open by the exhaust gasses.
Also your motor isn't tired, I had a motor well over 200000km and put in 25psi into it, last about 1.5 years of track use before it went bang LOL
Car looks good as now with the white bonnet.
Look at the curves.
At peak power boost has dropped dramatically. Earlier in the piece though, there is a near 40rwkw gain across the mid range.
  • Supply and install Haltech
  • Dyno tune
  • BKR7E gap 0.45mm
  • compression test
  •  Cyl1 - 115 Cyl2 - 105 Cyl3 - 130 Cyl4 - 110 Cyl5 - 110 Cyl6 - 122 -
  • re-plumb lines and idle control correctly and rectify boost leaks
  • block off bov
  • modified cold side cooler to fit iac
  • welded intake pipe up
  • install Injectors and injector plugs
  • install coil kit
  • wired wide band to ecu
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
