On 21/08/2019 at 11:57 PM, Milkmun said:
6psi extra for only a gain for 16rwkw?
More like 2psi up top, his actuator is weak hence his gate is being blown open by the exhaust gasses.
Also your motor isn't tired, I had a motor well over 200000km and put in 25psi into it, last about 1.5 years of track use before it went bang LOL
Car looks good as now with the white bonnet.
Look at the curves.
At peak power boost has dropped dramatically. Earlier in the piece though, there is a near 40rwkw gain across the mid range.
  • Supply and install Haltech
  • Dyno tune
  • BKR7E gap 0.45mm
  • compression test
  •  Cyl1 - 115 Cyl2 - 105 Cyl3 - 130 Cyl4 - 110 Cyl5 - 110 Cyl6 - 122 -
  • re-plumb lines and idle control correctly and rectify boost leaks
  • block off bov
  • modified cold side cooler to fit iac
  • welded intake pipe up
  • install Injectors and injector plugs
  • install coil kit
  • wired wide band to ecu
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
