Hi everyone, I'm a new member and I currently have a S14 zenki project car with a 1JZ swap using a conversion kit to a TR6060 (T56 type) transmission.
I'm towards the end of the project just with a few things I'm stuck on, I'm here to look for some solutions and post some questions that I'm having trouble with.
The end goal will be 500whp on E85 with a focus on an all-rounder car, at the moment I only have the standard skyline brakes upgrade so that will be upped in the future, it's got BCracing coilovers and all rear arms done, 18x9.5 concept concave rims with Hankook 255/35/18 rubber square stanced. The main engine mods are BC racing 264 cams, steel head gasket and ARP studs, then single turbo conversion to a GTX3582r at about a 0.69 a/r for good response. Fuel is on a upgraded sard top feed rail, with 1000cc bosch injectors and a walbro 455, this is going to be the limiting factor for making power off E85 so might have to see some upgrades here. The work still to do is workout how to fit an off the shelf shifter that fits in the car, or to go custom, then to have custom intercooler piping, exhaust, and recirculating valve installed, and finally to have all wiring and tuning done at the end. The car is currently unregistered so I'm going to have everything engineered and to the law.
Any suggestions or help along the way would be greatly appreciated,
Cheers guys.
https://www.sau.com.au/forums/topic/473363-hello/
As GTSBoy said ditch that silly rear housing mate thats WAY too small for a 35R! Choking it chasing "boost response" is madness! Just because you maybe making boost sooner doesn't mean you will be making more power sooner. Biggest internet fallacy EVER! .82 minimum for a 750hp turbo.
Edited by Mick_o
  • Like 2
https://www.sau.com.au/forums/topic/473363-hello/#findComment-7868277
    • So, I'm not a diff swapsies specialist, but I am pretty sure the 300zx ran an R220 not and R200 like the C34 Stagea, so I think it is of no use to you. As you said, all you need to do is get the centre swapped in the diff you have, which might be best done by a diff specialist. The current centre is probably desirable to someone to track so an easy path might be to swap your mechanical centre for someone with a standard centre (which is a viscous LSD, and almost certainly won't have any limited left). The only thing you have to watch swapping R200 internals between diffs is that the number of splines on your car's stub axles has to match the donor car, or you need the centre+stub axles and make sure they have the same number and pattern of bolt holes as your rear axles.  You swap your current ratio onto the new centre so you don't have to worry about matching the front. Alternatively, centres like the Nismo pro are much gentler (and have adjustable "tightness") so you could buy on of those from somewhere like Jesse Streeter or Nengun (noting it may cost you 1234% extra in tariffs by the time it lands)
    • Id just remove the solid subframe bushes.  you are over complicating things.  on a side note make sure you do some research on the skyline shed before buying from them.
    • Just got back from overseas and once again Rego and service time. Supercheap auto cant find my plates on their list to match my car to buy a crush washer lolol. NRMA has my number plate linked to R35 GTR which i have explained once again that it is not a GTR. Its scary in the sense that if somthing happens and my insurance wont cover me if its the wrong car on their list even though they are the ones that have made the mistake. Im not sure NIGHTCRAWLER why the neg comment? Its a 2020 V37 400R Skyline? and asking for someone to post their VIN number is crazy just to prove it? Its a legit Nissan Skyline from japan factory 400R its does use the Q50 infinity chasis but this is the Japan model.
    • no, you aren't, but good to see you pop by
    • I can also smell fuel in oil if that helps.
