Hi All,
Thought I would share my GTR as I get sent a lot of PM's with questions etc. happy to help anyone out, I'm new to GTR scene but not RB's having owned some big power RB30 VL's in my life, rwally enjoying the change but the do hurt the back pocket lol!
Lot people will probably know this GTR plates " HANIBL " has been on the Motive DVD GTR vids etc, was originally built by Team Karam with a straight 26 setup and then the owner went all out which when I was lucky enough to scoop it up when he sold it on a spare of the moment decision just after it was put back on the road with the new setup.
Quick run down on the car:
1992 GTR fully resprayed in original silver by 2SUS
RD diesel block, half grout, Nitto 3.2 stroker kit, full CNC 26 head with head sealing rings, billet plazmaman 12 injector inlet, 6 boost manifold with precision 8285 ( recent addition bought it with a 7675 ) 290 kelford cams, Elite 2000 ecu, mechanical fuel pump, external wet sump oil pump, Al's Raceglides AWD turbo 400, Quaife front diff, billet axles, full IHRA spec chromoly cage list goes on.
Car made 1183hp @ 45psi as a manual, car is currently being tuned by Ben D"Annello in Melbourne after some updates, we found the old cooler was no good so since upgraded to a plazmaman pro series 100mm cooler with immediate results, now just upgraded some wiring etc. and hoping to finish off the tune in the coming weeks, currently on 38psi has made 1050hp or 778rwkw thru the auto but some trigger miss count issues have held us back from turning it up or adding the timing it wants hence the wiring upgrades.
My aim for the car is just to run an 8 sec pass, everyone will say it will do it easy but I have had the cars in the past to do it and one way or another it just hasn't come together, so fingers crossed it will come together this time around, the car has no expense spared on it, I'm very fussy so plenty left to do but that's the enjoyment of owning a car.
Quick video and pics attached hope you enjoy.
HANIBL 38psi 8285.MOV
  • Like 10
https://www.sau.com.au/forums/topic/473365-hanibl-r32-gtr/
Finally got the car back on the dyno after fitting a new Haltech engine loom and trigger sensors.
No more miss counts, car ran perfect and was doing back to back 1100hp pulls thru the TH400 on just over 40 psi, we were being conservative given given all the small dramas we have had, left it quite rich and it has no boost control left so more wastegate springs needed if we want to lean on it a bit more.
Now to hit the track and back up the numbers.
HANIBL 42psi.MOV
  • Like 4
https://www.sau.com.au/forums/topic/473365-hanibl-r32-gtr/#findComment-7869411
  • 9 months later...
On ‎12‎/‎14‎/‎2018 at 6:25 PM, Taha said:
Hi any updates  and how much  power did 7675 make
Its actually got the 8285 on it, use to have the 7675 which is made 1170hp at the wheels when it was manual and 1000hp when it was auto.
https://www.sau.com.au/forums/topic/473365-hanibl-r32-gtr/#findComment-7894098
    • I was under the impression the reason why OEMs are going with solutions like relatively thin "right-sized" cylinder walls with technologies like PTWA and open deck is because they care a lot about whatever marginal knock margin benefits they get from that vs the structural rigidity benefits of a closed deck block and thicker cylinder walls. I also see some weird stuff like plastic inserts in the water jacket around the cylinders to try and equalize cylinder wall temperatures. re: the PRP blocks and heads at the end of the day it's hard to know what is and isn't going to work there, just have to see what the initial buyers say about it.
    • Which is why I didn't mention that hardness testing, and specifically mentioned the bore and deck thickness testing. Yeah, not really. The bore temperature will be a lot more even around the top half inch or so, where the material distribution is dominated by the deck, and which is the only place where the bore surface temperature heating any gas in the cylinder is likely to have any effect on detonation. Think about it. Another inch or so down the bore, you might have a hotter spot. The gas there might get a bit hotter, then the piston rises squeezes that gas away from there at high speed and mixes it with other gas from nearby. Instant dilution of the problem. I'd be surprised if it was an issue at any time other than in racing engines or OEM dev engines being run at the ragged edge of tuning. Say what now?
    • https://dsportmag.com/the-tech/education/engine-tech-material-hardness-testing/ The PRP testing on block hardness I'm not sure how much it actually can be trusted. The thinner cylinder walls on RBs is a bit of a problem vs 2JZ but it really depends on the design goal. Siamesed cylinder bores like a 2JZ cause uneven cylinder wall temps too, which means a bit of distortion induced by that + the hotspot can affect knock margin. Something that actually gives me a bit of pause with the PRP block, whether super thick cylinder walls are going to keep it from being drop-in compatible on an otherwise OEM rebuild.
    • Yeah very valid point. I am waiting for one of the other tuners to come back from vacation so he can help me a bit when the cat is installed again. In the meantime I am going to finish up my polishing and ceramic coating that I have started myself.    N45 Dr Beasley product is highly recommended for a paint primer / polisher. Using this EXO Gtechniq also for the ceramic but next time might use the light serum before hand also. Looks great.
    • Running rich in conditions where it shouldn't probably won't do great things for catalytic converter lifespan. I would fix that sooner than later.
