Selling a bunch of r33 gtr parts that come off the car due to upgrades or spares that are no longer needed. Prices do NOT include postage, that can be arranged at your expense if required. Local pickup is Townsville, North Queensland. I can get photos if the ones provided are not sufficient enough. This will be updated as I gather the remaining photos/parts to advertise. Will do my best to get back to you as soon as possible with a response.
1. FC-Datalogit for Power FC ECU - $300 firm; These are AUD $400+ brand new, has been used twice when I had a power fc to tune and log some issues. Comes with everything from when purchased new.
2. Power FC L Jetro + Handcontroller + Boost solenoid - $600 firm; Has a mild tune on it currently, was recently removed to upgrade to a Link G4. Not sure on it's flexibility if to be used with other cars (other than r33 gtr), model number in the photo below.
Edited by breaker1845
https://www.sau.com.au/forums/topic/473404-r33-gtr-parts/
More Parts added to the list. FC-Datalogit has sold.
2. Power FC L Jetro (RB26 model), ECU only - $400
3. TurboSmart E-boost street with solenoid - $300
4. Oil catch can - $100
5. Front pipe - $150
6. OEM Coilpacks (2 sets) - $100 each, all working and in good condition, removed due to upgrades
7. OEM Fuel rail, regulator and injectors (x2) - $250 each, all working and in good condition, removed due to upgrades
8. R33 gtr OEM turbos (x2) - some shaft play and removed in good condition, kms unknown - $100 a set
9. RB26 OEM Oil Pump - removed due to putting in a tomei - $50
10. RB26 OEM Water Pump - not that old but removed and put a new one in when doing rebuild - $50
11. HKS Exhaust Manifold for twin turbos (brand new was a spare) - $50
12. R33 OEM Cam gears - $50
13. R33 OEM Cam shafts - $50
14. OEM Nissan Head gasket (brand new) - $150
https://www.sau.com.au/forums/topic/473404-r33-gtr-parts/#findComment-7869380
  • 4 weeks later...
Bump. Open to offers on the items listed.
I also have a factory R33 gtr long nose crankshaft for sale. Came out of a working motor so its in good condition. Will post up some photos in the next few days.
https://www.sau.com.au/forums/topic/473404-r33-gtr-parts/#findComment-7871680
  • 3 weeks later...
  • 4 weeks later...
  • 4 weeks later...
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
