First serious mod done to the wagon: RWD "conversion". The reason: the wheels I got for her apparently had a slightly different rolling diameter (3mm) and neither ATTESSA nor my transmission were too happy about that. Yes, i could have gone through the trouble (and money) to find matching tyres (current tyres: Falken Azenis FK453 in near imaculate condition) but I don't think the mrs would have liked that too much. Dropping the shaft was pretty straight-forward, although I did resort to a dremel for some stubborn bolts :)
Yes, that's in front of my house
No, I don't have a garage
Yes, it was -2 degrees Celcius
  • Like 1
https://www.sau.com.au/forums/topic/473414-staceys-project-page/
So, last night as i was driving home from work my 4wd lamp started flashing. I figured this is logical considering i dropped the front shaft in the weekend. Just a  bit strange that it's started flashing now and not right away. My theory is that the attessa pump or ecu is going haywire. Any thougts on this? What would completely removing the attessa system do?
  • 3 weeks later...
Short clip of the wagon destroying a pair at the burnout contest last week. As you can see, lots of white smoke from the exhaust which tells me she's running really rich (because nissan....). I ordered a consult-bluetooth thing so I'll be testing that after the weekend. Next step would be an afr gauge/wideband sensor and some sort of AFC, although from what I've been reading lately it can get tricky considering she's an S1 auto...
VID-20180314-WA0002.mp4
  • Like 1
3 hours ago, Ben C34 said:
That's a decent effort.
What kind of wierd platform is that? Heaps different to Aussie burnout comps!
Yeah well considering she's completely stock and quiet as heck, yeah it was a pretty decent effort. It's my first time doing a burnout like that. Apparently that's how they do it here with the platform, might have something to do with safety or the fact that they (the racetrack owners) don't want their tarmac all ruined and stuff
Commentator is speaking Dutch so Netherlands or Belgium?
To OP; try disconnecting the switch to Attessa pump (see below) or you could just tape over the light! Have you pulled the 2 4wd fuses (one in the cabin fuse block behind the coin tray and one under the bonnet)?:
Locate the "air bleed" wire behind the drivers kick panel, it's a plug with a single wire either side (usually green socket, white plug).
In my S1 Stagea its a very small black plug taped to a loom with a single yellow wire with a green trace going to the plug and a single black wire going to the socket.
Disconnect it.
Start car. As key comes back to the ON position, within 10 seconds, depress brake pedal 5 times, 4WD light will start flashing to indicate you are in 2WD mode.
You need to do this every time you start the car.
To go back to 4WD mode, turn car off, reconnect plug and off you go.
And if you plan to do this a lot you can put a switch in somewhere.
Disconnect it.
I'm living in the Netherlands, yes :)
I've not pulled the fuses (yet) so that's the first thing i'll try. The car is basically always in 2wd mode since the front shaft has been removed, just the ecu doesn't know that i guess..
If the fuse thing doesn't work i'll do the bleed thing :)
  • 3 weeks later...
So, coming sunday i'll be going to a fellow wagoneer who's parting out his stagea. Gonna check out which parts i'll be taking, already made a list:
Tein Coilovers
Front Mount Intercooler
3" Turboback exhaust
Apexi Powerfilter
(R33) Gtr Brakes
Question is now, what differences i'll feel (aside from a slightly stiffer ride and a louder exhaust) with these mods? Will there be a significant increase in performance? Will defintely get it tuned after the mods.
  • 1 month later...
So, the time has come! I'll be picking up the above mentioned parts in the coming weeks :D
At the same time, i've been thinking out loud about doing a manual swap (surprise surprise). I've seen the writeup here and it's definitely insightful. However, i would like to stay the RWD route so instead of using a gtr box i'm considering a gtst box. Also, i'm pondering about what to do with the sump. I wanna believe that a rwd sump would fit, given i'd have to modify the oil pick up and drill/tap some holes.
Anything else i need to keep in mind when going this route (aside from everything mentioned in the writeup of course)?
    • Welcome!  We're not all grumpy.
    • Welcome. We're all grumpy old men (and a few grumpy old women) who are slowly coming to hate these cars. Any of the newer owners who have joined in the last few years are rapidly catching up with us as they realise they have bought a basket case and that parts are getting difficult to find. Just be realistic about your goals. You'll need a fat stack of cash to buy an R34 GTR, and you'd be far better off using that to buy absolutely anything else (ie, shares, a house, scratchy tickets) unless that fat stack of cash is only ~10% of the actual fat stack of cash that you have. You'll never want to drive an R34 GTR on the street if you have fear of it getting destroyed. That's more or less true of the 33s and 32s also. Most of the RWD cars have been drifted backwards into power poles. No-one knows what they are worth these days because they are not changing hands. My car has notionally been down to <$10k value at some point and was probably sellable for $40-$50k in the height of COVID stupidity, but I have no idea what it's really worth now. It's irreplaceable anyway, because... where would I find one to replace it? Being realistic means either paying a lot of cash for a really really clean example that you will only drive on sunny Sundays, or buying one to daily that you will not want to be really really clean, for the same fears of destruction that applies to the GTR. I daily mine and some people think I'm crazy. But....to me it's just a car that I bought last century with the express purpose of driving it as my daily. The silliness that has happened since doesn't affect my original purpose. I have well and truly amortised the initial purchase cost and most (probably all) of the subsequent modification costs. But I don't think I could go out and buy one now to daily.
    • This is insane! The M1 likely to be closed for the entire day!  https://www.abc.net.au/news/2025-05-02/m1-motorway-delays-as-metal-shards-cause-flat-tyres-/105242272
    • Hey everyone! I'm quite young and I don't have enough to get a car right now but I love Nissan Skylines (Specifically the r34 GT-R. I'm so original I know.) and I would love to buy one in the future. I have no background knowledge, only an interest in cars, but I'd love to learn how they work so I can mod in the future. I've done some basic research on what model of Skyline I would start with and what mods to get started with are but nothing else. I'm here to learn! Hope you all have a great day
