Pair of Bride Brix II seats in leather/gradient trim. One was originally a cloth seat that was retrimmed (can tell by the product code E14AGS and hence the difference in stitching at the headrest) and was purchased from Import Monky. The other was a leather seat from factory (E14AGR) purchased second hand. Both in good condition with a little bolster wear on the retrimmed seat as pictured. Rails are also genuine Bride rails to suit an R34 GTT. Rails were purchases from Jap Import Spares in SA. Have certificates for the rails. We’re only in my car for 6 month but removed because I sold the car in October. Have been sitting in my room since.
Pickup from Penrith area.
$1800 for the pair with rails.
Edited by vinceyboy28
https://www.sau.com.au/forums/topic/473418-bride-brix-ii/
Man these are rare theses days. I have a set of Brix II's that I wish matched.....ones a Brix II in leather with red stitch but with all black Bride gradation cloth insert and the other, a normal bride cloth Brix II...
If those rails fit my s13 I would buy in an instant!!!
Good luck with the sale man.
  • Thanks 1
https://www.sau.com.au/forums/topic/473418-bride-brix-ii/#findComment-7868917
  • 1 year later...
Cheers for the reply mate.
I'm guessing the re-trimmed one is still available? How much you looking for? Also , would you be happy to post to Adelaide?
I'll see if I can source another one in the meantime, really wanted that set! :)
https://www.sau.com.au/forums/topic/473418-bride-brix-ii/#findComment-7901715
No worries. Yes the re-trimmed one is the one I still have. I’ve attached some more recent pics for you. Was looking for $700. Happy to courier it if you cover the cost. 86394A9F-0767-4AE1-BB79-F7BC1237F9F7.thumb.jpeg.ae79c0915716111eb46a059f0f2cd88d.jpegC520FDB3-1F6B-4A48-A6D6-6D3A86CF9956.thumb.jpeg.80f12c946c1cf1d18cc15f197066ffcd.jpeg3974B313-604B-4B33-8BE2-DA7574C5EC67.thumb.jpeg.0f37180ff8fd9fdb23473f6aab33b4f4.jpeg498EBB99-BFA6-4894-820E-16FC7FF54976.thumb.jpeg.6f803f1909908a04e53b47d3bbd187c8.jpeg8BFD9DFA-FDB9-4726-A2D6-B16E48B122C8.thumb.jpeg.217e5b24b9a76fb1c08e7caafcd9787c.jpeg
https://www.sau.com.au/forums/topic/473418-bride-brix-ii/#findComment-7901724
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
