1989 BNR32 - 116XXX KM
$36,000
Hi all,
Time has come for me to move on from my pride and joy of 8 years. Over that time i have worked hard to get her to the point she is today, alas family has gotten in the way and i would like someone with the passion i have to take over. Car has been rebuilt, with full receipts for work done, and has had an interior overhaul.
All work done up until end 2016 done by ultimate tunes in Canberra, Tune is done by JEM in Sydney. Car is running map sensors, and is ready to be flex tuned. Car was flex tuned previously but i lost my local E85 shop so last retune i put it back to 98 (tuned to 300KW). Details are as follows:
Engine:
Nitto Pistons and Beam Rods
Nitto Oil Pump
Nitto Gasket kit
Tomei Type B cams, Springs, and Cam Gears
ARP Studs
Mishimoto Al Rad
Garrett 2860-7's
Custom front pipes with HKS Super Dragger exhaust (Stock dumps)
HKS hardpipe kit
HKS Kansai strut bar
HKS AFM delete pipes
ARC Super induction box
High octane catch can with braided lines
Triple plate clutch (can't remember the brand sorry)
ECU:
Haltech Platinum Pro
Haltech 3 Port Can Hub
Haltech Wideband controller
Haltech Flex Fuel Sensor
Haltech Io Expander
Haltech Boost Solenoid
Haltech 3 Bar Map Sensor
Exterior:
Resprayed a mix of gunmetal with blue
Bee*R B5 racing wheels with 595 RSR Semis
Fibreglass bonnet
Interior:
Nismo seat cover replacements
Nismo steering wheel with horn
Nismo floor mats
Nismo pedal set
Nismo boost gauge
Nismo rear vision cover
Nismo fashion lighter
Nismo gear knob
Defi din gauge set
Nissan option foot rest
Nissan option center console with cup holders
All in all she is in good shape for a car her age, with the following issues present:
Small amount of rust bottom side of firewall
Small oil leak coming from rear turbo
Throttlebody is slightly out of adjustment, recommend adjusting before going for a heap more power, safely turned around at the moment
gearbox Syncs are getting tired
Everything stated comes with the car, along with spares i have (original steering wheel etc). Slightly neg, can neg further if you want me to start removing nismo items. Car doesn't have rego, but can put more on if need be.
happy to discuss further/provide more info if needed.
  • Like 1
  • Sad 1
https://www.sau.com.au/forums/topic/473425-1989-bnr32/
12 minutes ago, RBN1 said:
Time has come eh? Lots spent on this car.
Make sure to put it on the various FB GTR pages. They go nuts for ones like this.
Good luck.
Cheers man
https://www.sau.com.au/forums/topic/473425-1989-bnr32/#findComment-7868915
  • 3 weeks later...
  • 3 weeks later...
    • I couldn't agree more. As an owner of a built high HP skyline, I'd be a hypocrite to not buy a Hummer for the reasons you listed though haha.
    • Hahaha oh shit! Again!
    • Is this the one? https://jpjdm.com/shop/index.php?id_product=2192&rewrite=nissan-stagea-c34-rear-boot-actuator-assembly-90550-0v000 Might be worth having a look at yahoo japan as well. Though it seems a bit odd. If the motor works itself, other than being noisy, then wouldn't it be more likely that it's an electrical issue somewhere else? And it being noisy does not seem as surprising if it has been chugging away for months
    • I know this thread is quite old, but I found it, it helped me, but I also wanted to add my experience and troubleshooting finds to the chat for others. I have not been able to open the rear hatch of my 97 Stagea for several months. Figured it had just really sealed itself up over the winter and I would just get to it eventually. Well that day was yesterday. Some time ago, I noticed my battery was going flat all the time. It was frustrating. Then one quiet night in the garage, I could hear and ever so slight humming / grinding noise coming from the back of the car. It was like a really quiet popping sound or something like sand in a very low speed blender. I took off the panels in the back and noticed the noise coming from the auto close motor, so I unplugged it and the noise stopped. And the auto close was disabled. Well, fast forward to yesterday, I tried all the tricks with power and fuse and lock and unlock and I still could open the damn hatch. So I took off the panels from the inside and found the auto lock had engaged and was stuck in close position. When plugging and unplugging the fuse, I could hear the relay clicking. So I plugged the autoclose motor back in, and the damn thing let go. And immediately started making that grinding sound again. This time, instead of just unplugging the motor, I pulled the fuse, thus depowering the relay entirely. I don't have the autoclose feature now, but at least I can open the boot and not have my battery being sucked dead all the time. Not sure what caused the motor to latch when it was unplugged from the system, but I am pretty sure it won't cause any more problems now.  If anyone has a lead on a new motor, please let me know. It's a cool feature that I would like to get back.  Hope this helps.
    • Lolololol maybe, man I hate this car. Lapsed judgement a respray and a new motor, when I should have just scrapped the lot when I had the chance. Farken.
