1989 BNR32 - 116XXX KM
$36,000
Hi all,
Time has come for me to move on from my pride and joy of 8 years. Over that time i have worked hard to get her to the point she is today, alas family has gotten in the way and i would like someone with the passion i have to take over. Car has been rebuilt, with full receipts for work done, and has had an interior overhaul.
All work done up until end 2016 done by ultimate tunes in Canberra, Tune is done by JEM in Sydney. Car is running map sensors, and is ready to be flex tuned. Car was flex tuned previously but i lost my local E85 shop so last retune i put it back to 98 (tuned to 300KW). Details are as follows:
Engine:
Nitto Pistons and Beam Rods
Nitto Oil Pump
Nitto Gasket kit
Tomei Type B cams, Springs, and Cam Gears
ARP Studs
Mishimoto Al Rad
Garrett 2860-7's
Custom front pipes with HKS Super Dragger exhaust (Stock dumps)
HKS hardpipe kit
HKS Kansai strut bar
HKS AFM delete pipes
ARC Super induction box
High octane catch can with braided lines
Triple plate clutch (can't remember the brand sorry)
ECU:
Haltech Platinum Pro
Haltech 3 Port Can Hub
Haltech Wideband controller
Haltech Flex Fuel Sensor
Haltech Io Expander
Haltech Boost Solenoid
Haltech 3 Bar Map Sensor
Exterior:
Resprayed a mix of gunmetal with blue
Bee*R B5 racing wheels with 595 RSR Semis
Fibreglass bonnet
Interior:
Nismo seat cover replacements
Nismo steering wheel with horn
Nismo floor mats
Nismo pedal set
Nismo boost gauge
Nismo rear vision cover
Nismo fashion lighter
Nismo gear knob
Defi din gauge set
Nissan option foot rest
Nissan option center console with cup holders
All in all she is in good shape for a car her age, with the following issues present:
Small amount of rust bottom side of firewall
Small oil leak coming from rear turbo
Throttlebody is slightly out of adjustment, recommend adjusting before going for a heap more power, safely turned around at the moment
gearbox Syncs are getting tired
Everything stated comes with the car, along with spares i have (original steering wheel etc). Slightly neg, can neg further if you want me to start removing nismo items. Car doesn't have rego, but can put more on if need be.
happy to discuss further/provide more info if needed.
  • Like 1
  • Sad 1
https://www.sau.com.au/forums/topic/473425-1989-bnr32/
12 minutes ago, RBN1 said:
Time has come eh? Lots spent on this car.
Make sure to put it on the various FB GTR pages. They go nuts for ones like this.
Good luck.
Cheers man
https://www.sau.com.au/forums/topic/473425-1989-bnr32/#findComment-7868915
  • 3 weeks later...
  • 3 weeks later...
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
