1996 Nissan Skyline R33 series 2.
engine:
rb25det (122,xxxk)
Gates Racing Timing belt, new bearings, power pump (was done while in the process of installing the bolt ons)
Brand New Radiator hoses (gates brand)
New Genuine nissan rocker cover gasket and half moon.
Project Mu anti spill bands (brake reservoir and power steering reservoir)
Project Mu Magnetic Drain plug
1000cc Xspurt Injectors
Walbro 460lph in tank (wired with milspec e85 submerssible wires and insulation.
New Bosch Alternator
New Gates Belts
Plazmaman Intake plenum
Plazmaman Metal intake gasket
Plazmaman/turbosmart collaboration fuel pressure regulator
Plazmaman billet throttle body
Plazmaman fuel rail
Plazmaman Intercooler (bar & fin)
Aluminium radiator with greddy high pressure cap
Toyota Yaris coilpacks
Nissan Cas with AEM 24 hole disc (great mod to reduce timing scatter)
6 boost manifold
New High tensile studs and nuts
Cometic MLS manifold gasket
turbosmart pro gate lite 50mm wastegate
screamer pipe
K&N 4" Pod Filter
K&N Pod filter sock
Garrett Gtx3076r .82 rear housing with t51r mod by OCD works in tennesse u.s.a (the pioneer of t51r mod. orgasmic turbo whistle gauranteed)
3.5 dumppipe
HKS Hi-power (bought from japan)
Turbosmart Ring worm clamps
Proflow:
-silicone joiners
-teflon braided lines
-e85 compatible fuel lines
-catch can
-all an fittings
Fabwork:
custom windscreen washer tank by full lock automotive
All turbo and exhaust pipings are done by proximity motorsports
Pcv delete and shave done by full lock automotive
gutted cat with test pipe done by soundrite exhaust shop
Drivetrain:
New 5 puk NPC Clutch (rated at 450kw)
Hel Braided clutch line
arp flywheel bolts
resurfaced stock flywheel
Redline Shockproof oil on the gearbox
Short shifter
gktech billet knob
Engine Management:
Link g4+ GTR/GTST
Link MAP sensor
Link wideband and CAN
Link/Continental Flex sensor (ethanol content and fuel temp)
Link Intake Air Temp Sensor
Link Boost Controller (MAC Valve)
Handling:
BC Coilovers (reds)
RDA drilled and slotted front rotors
EBC Reds Brake pads
Interior:
Custom paint job on dash and rocker covers with didspade prisima flakes.
Custom missile style switch for motorsport features (2step, anti-lag, ecu logging)
turbosmart boost gauge
Exterior:
WORK Emotion Kiwami 18x9.5 +22 on all 4
WORK lugnuts with security key
WORK Emotion center caps
Federal RSRR Semi slicks 265/35/r18 (square set up)
Gaurds are professionally rolled by proximity motorsport.
Car is tuned by JP Tuning
Fabwork is done by Proximity Motorsport & Full Lock Automotive
Mechanical work is done by Proximity Motorsport.
Currently making a safe 460hp on E85 and 400 on 98
2 step launch control is activated by a switch.
car is well looked after inside and out
and oil service every 4500-5000k using penrite ten/tenths and HKS Race oil filter.
I got another car coming and selling this car would help me pay off the new one that ill be getting.
Grab yourself a bargain for a really steal price of $15,000. anyone that has build a car like this knows that this is pretty much a give away price. car will be sold unregistered
Price is firm!
you can email me at [email protected] or contact me 0422792934.
Edited by Spagett
  • Like 1
  • 3 weeks later...
    • Ha ha ha! I know those feels mate I've finally got the garage cleared enough that next weekend I'll do some actual work on my car (hopefully). Unfortunately garage isn't usable after 10am at the moment That said, I've done a lot of work this weekend on helping finalise a friend's Production Race car. Full started Christmas Eve. We're down to about 8 tasks on the list, including "get a wheel alignment". Sometimes it's just easier working on someone else's car or project than our own stuff 😛
    • Ha ha, ended up going it alone.  I just sent it (in a very nervous fashion).  Once I'd released the locks and it didn't automatically start spinning out of control i felt a bit more confident.   It made some loud sounds (cracking and creaking noises) when I first spun it which got the heart rate going again!  I couldn't bring myself to leave it tipped on the side.  I feel a bit more comfortable having back right side up while it sits there. I'd get angry with your last point but you're 100% correct! 😅 Even yesterday I managed to distract myself at numerous times to make a bracket to fit an LED flood light off the back of the house and fix my sons pushbike.  There were other little taks nibbling at my brain for the rest of the day too...
    • Probably one of the more nerve wracking experiences of my entire life! 😂😂 The balance (centre of gravity) is out still but in a direction that gives me comfort!   It's quite bottom heavy still meaning it takes a bit of muscle to rotate it.  The plus side of that is that it wants to to go back to upright.  Better that than wanting to go all stranded turtle on me!
    • hmmm that's not ideal. This is a pretty new engine right, will be interesting if your engine guy has any theories about causes
    • A universal ball joint removal c press kit is better money spent and will work for the Hicas ball joints.  Here's a 45$ CAD Example. ATPEAM Heavy Duty Ball Joint Press Kit with 4WD Adapters | Professional 4 in 1 Ball Joint Press Removal and Installation Tool for Cars and Trucks | Universal Ball Joint Tool with Storage Case, Ball Joint & Tie Rod Tools - Amazon Canada
