Hi from SA
Not sure yet. Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that馃ぃ So maybe giken gear set, but I'm afraid it won't be strong enough馃檮
Keeping in mind that for most people this is a week to month long job!
Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled? If you unplug the IACV, what rpm does the engine idle at?
