  • 3 months later...
For posterity....did you confirm it was M24 x 1.5?
Depending on the damage, you would also be able to remove the thread from the first 5mm or so of the shaft (eg with a grinder) as the nut must go beyond there to be tight and to allow a split or R pin to be inserted. I've cleaned a smashed evo shaft up that way and it worked fine.
