Regrettable sale of my manual 1998 R34 25GT-T 4 Door.
It has been my daily drive for work but due to house commitments it must go :( . This has been a great car to drive, we have just done some service items, wheels and rego since owning it.
Air conditioning works and is nice and cold! Does not leak a drop of oil and we have never had any issues with police. No accident history. No finance owing. Fresh 6 months rego.
Engine:
  • RB25DET Neo
  • Blitz SUS Power LM air filter
  • HKS return flow intercooler
  • GReddy Profec Type-S Electronic boost controller
  • Blitz Duel drive BOV
  • New fuel filter
  • New 02 sensor
  • New spark plugs
  • Fujistubo 3.5" stainless Cat Back
  • JJR stainless dump
  • OS Giken adjustable Ex. Cam Gear
  • GReddy timing belt
  • Genuine Thermostat
  • Genuine Water Pump
  • Gates Racing drive belts
  • New Cam, 1/2 Moon's, Front Main, Rear Main, Cam Cover Seals
  • Odyssey Dry Cell Battery relocated to the boot.
Drivetrain:
  • R33 RB25DET Gearbox - 4:11 Diff gears
  • EXEDY cushioned button clutch (near new)
  • Suspension and Brakes:
  • KTS Coilovers
  • KTS Castor arms
  • KTS Rear Camber arms
  • KTS Rear traction arms
  • KTS subframe mounts
  • KTS Diff mounts
  • KTS Tie rod ends
  • HICAS Canceler bar
  • Extra lock washers
  • Whiteline Front 27mm Swaybar
  • Whiteline Rear 24mm adjustable swaybar
  • Cusco Front Camber arms
Exterior:
  • R34 GTR Black
  • Factory Aero Front Lip
  • Factory Aero Side Skirts
  • Factory Aero Rear Pods
  • Factory Boot Lip
  • Vanquich Roof Wing
  • Factory Weather Strips
  • Carbon Fibre air dam
  • Genuine Nissan Clear Front Indicators
  • Rolled Front + Rear guards
  • 14% Tint + Windscreen strip
  • Uras eye lidsimageproxy.php?img=&key=4b1e78680f916b86
Interior:
  • Factory Triple Gauges
  • Kenwood Double DIN DVD Unit
  • Nismo duracon gear knob
  • Genuine floor mats
  • Stripped ALL sound deadening out under carpet
  • Genuine Defi gauges (water temp, boost)
  • Professionally relocated fuse box to boot
Wheels:
  • Front 18 x 9.5 + 15 CST
  • Rear: 18 x 9 +30 CST
  • New NITTO INVO tyres -225/40/18 F & 245/40/18 R
Cons:
  • Paint has some chips and marks
  • Gearbox has a slight noise
Pros:
  • Engineered for all mods, certificate included!
  • Lots of money spent getting the car to this point
  • Fresh rego just put on Wheels and tyres alone are worth almost $2500
  • Low Kms (133,915)
Rego till August 2018
Price: $ 14000 (or less if you BYO wheels), NO swaps please.
Located Central Coast, NSW
Please contact my partner Matt if you’re interested on 0481374381
Thanks.
Edited by kimmeh
  • Like 4
https://www.sau.com.au/forums/topic/473477-r34-gtt-4-door/
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
