Regrettable sale of my manual 1998 R34 25GT-T 4 Door.
It has been my daily drive for work but due to house commitments it must go :( . This has been a great car to drive, we have just done some service items, wheels and rego since owning it.
Air conditioning works and is nice and cold! Does not leak a drop of oil and we have never had any issues with police. No accident history. No finance owing. Fresh 6 months rego.
Engine:
  • RB25DET Neo
  • Blitz SUS Power LM air filter
  • HKS return flow intercooler
  • GReddy Profec Type-S Electronic boost controller
  • Blitz Duel drive BOV
  • New fuel filter
  • New 02 sensor
  • New spark plugs
  • Fujistubo 3.5" stainless Cat Back
  • JJR stainless dump
  • OS Giken adjustable Ex. Cam Gear
  • GReddy timing belt
  • Genuine Thermostat
  • Genuine Water Pump
  • Gates Racing drive belts
  • New Cam, 1/2 Moon's, Front Main, Rear Main, Cam Cover Seals
  • Odyssey Dry Cell Battery relocated to the boot.
Drivetrain:
  • R33 RB25DET Gearbox - 4:11 Diff gears
  • EXEDY cushioned button clutch (near new)
  • Suspension and Brakes:
  • KTS Coilovers
  • KTS Castor arms
  • KTS Rear Camber arms
  • KTS Rear traction arms
  • KTS subframe mounts
  • KTS Diff mounts
  • KTS Tie rod ends
  • HICAS Canceler bar
  • Extra lock washers
  • Whiteline Front 27mm Swaybar
  • Whiteline Rear 24mm adjustable swaybar
  • Cusco Front Camber arms
Exterior:
  • R34 GTR Black
  • Factory Aero Front Lip
  • Factory Aero Side Skirts
  • Factory Aero Rear Pods
  • Factory Boot Lip
  • Vanquich Roof Wing
  • Factory Weather Strips
  • Carbon Fibre air dam
  • Genuine Nissan Clear Front Indicators
  • Rolled Front + Rear guards
  • 14% Tint + Windscreen strip
  • Uras eye lidsimageproxy.php?img=&key=4b1e78680f916b86
Interior:
  • Factory Triple Gauges
  • Kenwood Double DIN DVD Unit
  • Nismo duracon gear knob
  • Genuine floor mats
  • Stripped ALL sound deadening out under carpet
  • Genuine Defi gauges (water temp, boost)
  • Professionally relocated fuse box to boot
Wheels:
  • Front 18 x 9.5 + 15 CST
  • Rear: 18 x 9 +30 CST
  • New NITTO INVO tyres -225/40/18 F & 245/40/18 R
Cons:
  • Paint has some chips and marks
  • Gearbox has a slight noise
Pros:
  • Engineered for all mods, certificate included!
  • Lots of money spent getting the car to this point
  • Fresh rego just put on Wheels and tyres alone are worth almost $2500
  • Low Kms (133,915)
Rego till August 2018
Price: $ 14000 (or less if you BYO wheels), NO swaps please.
Located Central Coast, NSW
Please contact my partner Matt if you’re interested on 0481374381
Thanks.
Edited by kimmeh
  • Like 4
https://www.sau.com.au/forums/topic/473477-r34-gtt-4-door/
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
    • sorry dude i forget about the forum sometimes. sent you a pm
    • Hell yeah. It's not as if the path from front to rear is particularly squirrelly or otherwise difficult.
