They don't seem to be included in last week's compulsory recall. https://www.productsafety.gov.au/recalls/compulsory-takata-airbag-recall/takata-airbag-recalls-list#id12
I'm not aware if Nissan issued a previous voluntary recall, but go here and run your VIN to check: http://www.nissan.com.au/owners/owner-information/takata-airbag-recall
  • Like 2
Good info!
  • Like 1
  • 7 months later...
Hi guys, I just saw a recent episode of 60 Minutes about Takata's exploding airbags so jumped on the IMABS website to see if our cars are affected and got the below message advising that it's unrecognised our their database possibly because it's an import so I rang Nissan and after a few transfers got to a public relations department and they couldn't advise definitively if our cars are affected or not because it's an older grey import.
I don't know. I'm a bit concerned and was wondering if anyone has had any luck in finding out further details?
Thanks.
59 minutes ago, Robocop2310 said:
Thanks guys.
I have a 1996 R33 GTR and 1999 R34 GTR.
Anyone with similar care having got the all clear? I have rung Nissan several times and they have not been forthcoming.
If your car is an import Nissan Australia won't give a shit. That's how it works.
2 hours ago, Old Rev Head said:
I have a 96 R33 twin airbag, rang Nissan Australia and spoke to customer relations. Gave them the Aussie VIN and Nissan original chassis number and got the all clear on that one.
Old Rev Head seems to have had some luck.
1 hour ago, Ben C34 said:
Aussie vin. I take that as being an Aus delivered car in which case they do care.
Car was imported to Australia 15 years ago by my father, and was first registered here 3 months ago, (don;t ask that's for another time). The 6U number is stamped into the body by the RAWS when it gets to Aus to comply with A.D.R. laws.
Can SAU write to Nissan as a club or try contacting them as I don’t know about others, but I hate uncertainty and I’ve tried contacting them and as some have corrected said they don’t give a damn about grey imports.
Like most, I don’t want to lose an eye or have half my face mangles by an airbag that’s suoopsss to safe lives.
It took half a minute to find this info:
http://www.ironchefimports.com/2017/07/24/takata-airbag-recall-for-dummies/
which leads to:
http://www.nissan.co.jp/RECALL/search.html
Search. Confirm. Relax (or freak out depending on the results)
  • Like 3
  • Thanks 1
which leads to:
I'll make this an easy-to-find link on the site. Thanks for posting.
  • Like 1
5 hours ago, Dose Pipe Sutututu said:
simply just too old
has any ever had their 90's era car air-bag go off? wondering if they even work at all
Edit: I've hit a few kangaroos and never set anything off, but not sure how much of an impact is required.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
