6 minutes ago, GTofuS-T said:
has any ever had their 90's era car air-bag go off? wondering if they even work at all
Edit: I've hit a few kangaroos and never set anything off, but not sure how much of an impact is required.
I’m no air bag expert but I have been in a accident where an air bag was deployed so can speak from experience that it went off when most of the front was totally damaged.
They are supposed to last a very long time whatever that equates to your guess is good as mine.
6 minutes ago, Dose Pipe Sutututu said:
Then you go remove your airbag because you don't want to die, just to be defected by the cops and fail your inspection LOL... can't win.
considering the replacement for affected cars is reportedly an 18 months wait, and recently a guy died from one of these days or weeks from replacement, you could argue (probably in court) that removal was justified for fear of safety?
This is exactly why I feel uneasy as we don’t know for sure whether our cars are affected or not and no one seems to know for sure.
So, in Australian delivered cars it goes back to 1999 (E46 BMW). https://www.productsafety.gov.au/recalls/compulsory-takata-airbag-recall/takata-airbag-recalls-list
Interestingly, no E90's are affected.
Wikipedia has more info but fails to cover the vehicles affected - perhaps a liability issue? https://en.wikipedia.org/wiki/Takata_Corporation#Cars_affected
Hey mate, thanks for the info. Still doesn’t specifically exclude our cars but it does tend to suggest we are not.
One can only hope we don’t find out the hard way!
Considering the number of these airbags in circulation and only ~25 deaths and ~250 injuries your odds are pretty good.
1 hour ago, r32-25t said:
I don’t understand how this issues goes so far back and they’ve only worked it out 18 or so months ago
Yeah me neither, clearly some ball dropping going on.
Yep agreed but I would hate to be the 1-5% chance with a hole through my face.
  • Like 1
3 hours ago, PranK said:
Hmmmm the other link doesn't mention e90s at all.
The link in your post further up the page lists E90s - it shows as "E8x 1 series, E83 X3 and E9x 3 series" - thats the link I followed to get the page I linked.
My airbag was replaced a few months ago by BMW. Is your steering wheel a BMW supplied one?
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
