Mechanic is having trouble with the different height valve springs. If going solid eliminates the Vct does that mean I can use same height valve springs on each side?
Have Tomei Solid 272 cams 9.25 lift as well as the Tomei lifters, What springs would I need to make this work with my current parts and will I need anthing else?
https://www.sau.com.au/forums/topic/473479-r33-s2-solid-conversion/
because the springs are different lengths on each side and the cams run big clearance he says he is having trouble figuring out what springs I need and how to make it work with what I have. He has suggested to me buying a whole supertech kit, but the supetech kit has same size valve springs on each side, and he keeps telling me I need different sizes on each side to make my parts work so I am also really confused and not too great with this stuff
Your not the first person to do this. Im sure its not as hard as he is making out. I would take above advice
He is contradicting himself and in my opinion whenever someone is doing that, they arent real sure what they are doing
Managed to talk to someone from crow cams that happened to be there who said he did a conversion not too long ago. Said because the springs are different size you need two different springs that aren't even listen as rb25 springs and said he would get the part numbers for me. He also suggested buying a washer seat on the exhaust side to  make it the right height.
    • I see you've never had to push start your own car... You could save some weight right now...
    • Sounds good.  I don't 100% understand what your getting at here. When you say, "I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down" do you mean this - there is a panel with factory paint, without any prep work, they paint the entire panel with primer, then colour then clear?  If that's what you mean, sure it will "stick" for a year, 2 years, maybe 3 years? Who knows. But at some stage it will flake off and when it does it's going to come off in huge chunks and look horrific.  Of course read your technical data sheet for your paint, but generally speaking, you can apply primer to a scuffed/prepped clear coat. Generally speaking, I wouldn't do this. I would scuff/prep the clear and then lay colour then clear. Adding the primer to these steps just adds cost and time. It will stick to the clear coat provided it has been appropriately scuffed/prepped first.  When you say, "but the new paint is landing on the old clearcoat" I am imagining someone not masking up the car and just letting overspray go wherever it wants. Surely this isn't what you mean?  So I'll assume the following scenario - there is a small scratch. The person manages to somehow fill the scratch and now has a perfectly flat surface. They then spray colour and clear over this small masked off section of the car. Is this what you mean? If this is the case, yes the new paint will eventually flake off in X number of years time.  The easy solution is to scuff/prep all of the paint that hasn't been masked off in the repair area then lay the paint.  So you want to prep the surface, lay primer, then lay filler, then lay primer, then colour, then clear?  Life seems so much simpler if you prep, fill, primer, colour then clear.  There are very few reasons to go to bare metal. Chasing rust is a good example of why you'd go to bare metal.  A simple dent, there is no way in hell I'm going to bare metal for that repair. I've got enough on my plate without creating extra work for myself lol.
    • Hi, Got the membership renewal email but haven't acted yet.  I need to change my address first. So if somebody can email me so I can change it that would be good.
    • Bit of a similar question, apprently with epoxy primer you can just sand the panel to 240 grit then apply it and put body filler on top. So does that basically mean you almost never have to go to bare metal for simple dents?
