Hey guys, I’m fairly new to the skyline scene, but looking to buy an r34.
My plan is to eventually upgrade to a larger turbo, maybe make 400-500 hp.
Is it worth paying the extra $5000? for a gtt if I am going to redo the turbo system anyway.
I understand that there are other upgrades in the gtt, but I am not sure exactly what.
I am not sure how much more expensive it is to turbo the gt model, compared to upgrading the turbo system in the gtt
Cheers,
Josh
https://www.sau.com.au/forums/topic/473512-r34-25gt-or-25gt-t/
Please do a search for RB25DE+T or DE+T e.g. https://www.sau.com.au/forums/topic/335781-r34-rb25de-to-turbo-conversion/
In short, turboing an NA car is not worth it. Here's what the GTT has over the GT, among other things: stronger gearbox, bigger brakes, bigger wheels for the bigger brakes, rear swaybar, sidemount intercooler, everything in the right location in the engine bay. Possibly some differences in cooling also (rad, PS, auto gearbox). Fully converting a GT to a GTT is possible but a big job - just save up and buy a proper GTT. Better yet, buy someone else's 500hp car with everything done already.
Another solid myth is that buying an auto can be magically converted manual cheaper that buying a manual in the first place. Not true. Been there done that. If you want a manual, buy a manual.
Good luck.
  • Like 2
Good luck.
Agree with your points although buying someone elses 500hp car is not always the best option. I'd rather a stock/fairly stock and do all the work myself, that's half the fun of having a project car isn't it? Building it to where you want it to be as well as the fact you know the car has probably been thrashed already if it has 500hp.
Edited by Gymkhana
  • Like 1
Good luck.
Cheers for the help man, kinda figured this would be the case; but didn't know there were that many differences.
  • Like 1
Yea for sure, definitely going to buy a fairly stock car, looking to keep this as a project car for the next couple of years at least
Only trouble with that is you lose your social life, own 2 pair of jeans [one with holes in the knees] and around 4 or 5 cheap T shirts with grease spots and welding/grinding holes in them and you live on noodles or cuppa soups cos you have nil time and $$$ to waste on food or clothes when there are important things like manifolds and turbo's to buy.
BTW....I have a THAT wardrobe, but my diet has progressed a little bit :) to include meat etc
Oh and get used to your gf/wife/partner rolling their eyes
But its all a journey...good luck man.
People forget that buying a finished project car isn't missing out of the fun of a project car.
The "fun" of a project car is keeping it running and trying to use it. There's more work in keeping it running than there EVER is in building it.
Buy Jussi's car and be happy
/Thread
  • Like 2
I don't think anyone's pointed out yet that the power you can get from a genuine DET will always be more and easier than from a DE+t. So if you have a particular power figure in mind you might only have one choice really.
I've done the DE+t and the sense of satisfaction is pretty awesome. I'd have had to wait a lot longer to buy a GTT and the moment might have just slipped away. Keep saving and watch the prices rise. My budget would probably have got me a GTST at the time but I wanted the R34. It might have been non-turbo for a few years but at least I was driving it. I gradually did the supporting mods - brakes, suspension etc.  before the turbo conversion. If you're ok with spanners it's not hard, not particularly time consuming and not that expensive if you're patient about looking for good deals.
Perhaps in the UK but certainly not in Aus or NZ :)
The cheapest GTT right now on CarSales is AU$8k. TradeMe has one with a 26 in it for NZ$10k...
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
