Hey guys, I’m fairly new to the skyline scene, but looking to buy an r34.
My plan is to eventually upgrade to a larger turbo, maybe make 400-500 hp.
Is it worth paying the extra $5000? for a gtt if I am going to redo the turbo system anyway.
I understand that there are other upgrades in the gtt, but I am not sure exactly what.
I am not sure how much more expensive it is to turbo the gt model, compared to upgrading the turbo system in the gtt
Cheers,
Josh
https://www.sau.com.au/forums/topic/473512-r34-25gt-or-25gt-t/
Please do a search for RB25DE+T or DE+T e.g. https://www.sau.com.au/forums/topic/335781-r34-rb25de-to-turbo-conversion/
In short, turboing an NA car is not worth it. Here's what the GTT has over the GT, among other things: stronger gearbox, bigger brakes, bigger wheels for the bigger brakes, rear swaybar, sidemount intercooler, everything in the right location in the engine bay. Possibly some differences in cooling also (rad, PS, auto gearbox). Fully converting a GT to a GTT is possible but a big job - just save up and buy a proper GTT. Better yet, buy someone else's 500hp car with everything done already.
Another solid myth is that buying an auto can be magically converted manual cheaper that buying a manual in the first place. Not true. Been there done that. If you want a manual, buy a manual.
Good luck.
  • Like 2
Good luck.
Agree with your points although buying someone elses 500hp car is not always the best option. I'd rather a stock/fairly stock and do all the work myself, that's half the fun of having a project car isn't it? Building it to where you want it to be as well as the fact you know the car has probably been thrashed already if it has 500hp.
Edited by Gymkhana
  • Like 1
Good luck.
Cheers for the help man, kinda figured this would be the case; but didn't know there were that many differences.
  • Like 1
Yea for sure, definitely going to buy a fairly stock car, looking to keep this as a project car for the next couple of years at least
Only trouble with that is you lose your social life, own 2 pair of jeans [one with holes in the knees] and around 4 or 5 cheap T shirts with grease spots and welding/grinding holes in them and you live on noodles or cuppa soups cos you have nil time and $$$ to waste on food or clothes when there are important things like manifolds and turbo's to buy.
BTW....I have a THAT wardrobe, but my diet has progressed a little bit :) to include meat etc
Oh and get used to your gf/wife/partner rolling their eyes
But its all a journey...good luck man.
People forget that buying a finished project car isn't missing out of the fun of a project car.
The "fun" of a project car is keeping it running and trying to use it. There's more work in keeping it running than there EVER is in building it.
Buy Jussi's car and be happy
/Thread
  • Like 2
I don't think anyone's pointed out yet that the power you can get from a genuine DET will always be more and easier than from a DE+t. So if you have a particular power figure in mind you might only have one choice really.
I've done the DE+t and the sense of satisfaction is pretty awesome. I'd have had to wait a lot longer to buy a GTT and the moment might have just slipped away. Keep saving and watch the prices rise. My budget would probably have got me a GTST at the time but I wanted the R34. It might have been non-turbo for a few years but at least I was driving it. I gradually did the supporting mods - brakes, suspension etc.  before the turbo conversion. If you're ok with spanners it's not hard, not particularly time consuming and not that expensive if you're patient about looking for good deals.
Perhaps in the UK but certainly not in Aus or NZ :)
The cheapest GTT right now on CarSales is AU$8k. TradeMe has one with a 26 in it for NZ$10k...
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
