So I am about to start a Nitto 2.8 build on my 33 GTR and an already built Nitto 2.8 by CRD has popped up on the market with only 2200kms on it.
Would I be better off buying the prebuilt 2.8 or building myself?
My mechanic swears by building yourself so you know what you are getting and not get ripped off but if it potentially saves me $$ in the long run if the motor checks out by contacting CRD and Jem about the build, would it be worth it?
https://www.sau.com.au/forums/topic/473520-better-to-buy-a-motor-already-built/
Well, apart from the silly power claim, if the engine is that new, is directly known by the builder and the builder & tuner can vouch for the lack of stupidity of the owner (a big ask, frankly), then it is possibly a good way to get such an engine without the hassle of building it.
But at $35k......there's still a lot of risk associated with the idea.
  • Like 2
I have spoken to JEM about it and they vouch for the car and also have spoken to the owner of the motor in depth over the phone about it.
Watched a dyno pull of the car making the 602kws.
I’m just unsure cause I don’t want to buy it then have the thing grenade in 5000kms time and no warranty on the build lol
Maybe I should just go with my gut instinct and do my own build
Why not build your own for 35k?
Not hating but it's such a good engine why is it for sale?
You arent exactly getting it for a steal. Its a lot of money.
The owner is pulling the donk out and returning the car back to stock.
He seems very genuine and was telling me about his business plans and reasons for removing the motor.
I think I’m just gunna build my own to be honest though. I already have a different hotside setup that I want to run anyway and he isn’t willing to part the motor.
I guess it was a moment of weakness for me when it popped up for sale haha
If youre staring down thebarrell of spending 30-40k imo build your own.
You know its all new gear. At the sort of money you don't want someone elses stuff.
I considered second hand turbo setups and other parts but ppl want basically new prices for second hand gear. I dont care how good of a recommendation it has. You are better off making a new purchase with a receipt and be the first one to use it.
  • Like 2
Do you even get a warranty on a build like that?
Will your mechanic make money building you an engine? If yes his advice isn't impartial.
My place of work will be building it and I served in the army with my mechanic for 10yrs and we will be building it together so his advice is good advice lol
You would kick yourself if you encountered an issue down the track. Stripped it down and found an issue in the build. There obviously would be no comeback on the builder etc. at 600kws there would be no warranties anyway as pointed out above. I take it your building a beast to drive on the strip only? It wont be a daily without it being detuned allot for daily duties, and that's wasteful and expensive. Have you ever driven something with that amount of power?
  • Like 1
It is a big risk for a huge amount of money. How much power are you chasing?
If it was me, i would buy a RIPS rb30 or simply forge your own engine. Talk to tuning shops and they may even offer a warranty on the build to the dyno tune. Even to the final tune if they limit the rpm and boost.
Piece of mind to save stress and a hole in the pocket.
Regards mate
  • Like 1
I must be missing something here. Can people please advise which shops offer warranty on performance engines?
Im not talking about after sale support because you spent heaps of money there im talking aboutmore than that.
Hey, i dont want to spread bs information but i seem to remember a tuning shop that offers a warranty on a complete build and tuning up to the first start and initial tune performed on their dyno.
Once the car is started, the initial breakin is performed on dyno by the shop, oil changed and is tuned.
After that, the warranty is over.
I dont know if this was a one-off or common practice but seems reasonable when a customer asks for a full, all included turn key package where there are no outside factors to affect the finished product.
    • Welcome!  How long have you had it? And what colour is it?
    • "CAD" version 1.0 It will have a 15mm lip around the top for 6 × 5 or 6mm nutserts and fixtures (two on each of the three straight edges), and some pinch weld on any exposed edges, it has three mounting points, one of the power steering reservoir bolts, and two on the rad support, my 120mm hole saw will make short work of hole for the silicone joiner, with ample room for some pinch weld  I've also got enough Carbuilders "peel and stick" heat shield to cover the outside of it at the coolant expansion tank and on the engine side, as pictured, and internally on the lid and where the fuse box is, I've also got some thin, about 3mm, black 3M single sided sticky foam stuff that was left over after sealing some door drafts at home to help seal the lid As for the shape, it "sort of" matches the shape of the fuse box, so shouldn't look to "out of place" The lower area and hole for the intake will need pinch weld with a balloon on it to fully seal the hole and bottom of it, that will happen after it has been fabricated so I know exactly what size is required  Filter service has been trialed,  and so far it was a simple process  Just need to get some alloy, and then head into work to use the guillotine and break press in the workshop Hopefully it should be sorted in a week or two Guestimated outlay will be under a $50 for the stuff I don't have on hand (alloy, 6mm nutserts, the pinch weld, and wrinkle paint) Disclaimer: That's what the "voices in my head" are telling me how the filter box should end up getting done......lets see if they know what they are talking about
    • Have been polishing up the trailer rims as they had been sitting in the shed for a few years and are really in need of some love. This was after a couple of passes with chrome polish - coming up quite well ✅ .
    • Welcome aboard! Is your Skyline auto or manual? I'm assuming manual. Does it have any mods done yet?
    • Hey mate, the brown and grey plugs would usually go to the TPS, brown one goes on the bottom connector and grey is the top but isn't used unless the car is auto, your TPS looks different to mine though I've got a series 2 engine.
