So I am about to start a Nitto 2.8 build on my 33 GTR and an already built Nitto 2.8 by CRD has popped up on the market with only 2200kms on it.
Would I be better off buying the prebuilt 2.8 or building myself?
My mechanic swears by building yourself so you know what you are getting and not get ripped off but if it potentially saves me $$ in the long run if the motor checks out by contacting CRD and Jem about the build, would it be worth it?
https://www.sau.com.au/forums/topic/473520-better-to-buy-a-motor-already-built/
Well, apart from the silly power claim, if the engine is that new, is directly known by the builder and the builder & tuner can vouch for the lack of stupidity of the owner (a big ask, frankly), then it is possibly a good way to get such an engine without the hassle of building it.
But at $35k......there's still a lot of risk associated with the idea.
  • Like 2
I have spoken to JEM about it and they vouch for the car and also have spoken to the owner of the motor in depth over the phone about it.
Watched a dyno pull of the car making the 602kws.
I’m just unsure cause I don’t want to buy it then have the thing grenade in 5000kms time and no warranty on the build lol
Maybe I should just go with my gut instinct and do my own build
Why not build your own for 35k?
Not hating but it's such a good engine why is it for sale?
You arent exactly getting it for a steal. Its a lot of money.
The owner is pulling the donk out and returning the car back to stock.
He seems very genuine and was telling me about his business plans and reasons for removing the motor.
I think I’m just gunna build my own to be honest though. I already have a different hotside setup that I want to run anyway and he isn’t willing to part the motor.
I guess it was a moment of weakness for me when it popped up for sale haha
If youre staring down thebarrell of spending 30-40k imo build your own.
You know its all new gear. At the sort of money you don't want someone elses stuff.
I considered second hand turbo setups and other parts but ppl want basically new prices for second hand gear. I dont care how good of a recommendation it has. You are better off making a new purchase with a receipt and be the first one to use it.
  • Like 2
Do you even get a warranty on a build like that?
Will your mechanic make money building you an engine? If yes his advice isn't impartial.
My place of work will be building it and I served in the army with my mechanic for 10yrs and we will be building it together so his advice is good advice lol
You would kick yourself if you encountered an issue down the track. Stripped it down and found an issue in the build. There obviously would be no comeback on the builder etc. at 600kws there would be no warranties anyway as pointed out above. I take it your building a beast to drive on the strip only? It wont be a daily without it being detuned allot for daily duties, and that's wasteful and expensive. Have you ever driven something with that amount of power?
  • Like 1
It is a big risk for a huge amount of money. How much power are you chasing?
If it was me, i would buy a RIPS rb30 or simply forge your own engine. Talk to tuning shops and they may even offer a warranty on the build to the dyno tune. Even to the final tune if they limit the rpm and boost.
Piece of mind to save stress and a hole in the pocket.
Regards mate
  • Like 1
I must be missing something here. Can people please advise which shops offer warranty on performance engines?
Im not talking about after sale support because you spent heaps of money there im talking aboutmore than that.
Hey, i dont want to spread bs information but i seem to remember a tuning shop that offers a warranty on a complete build and tuning up to the first start and initial tune performed on their dyno.
Once the car is started, the initial breakin is performed on dyno by the shop, oil changed and is tuned.
After that, the warranty is over.
I dont know if this was a one-off or common practice but seems reasonable when a customer asks for a full, all included turn key package where there are no outside factors to affect the finished product.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
