Skitzvk Posted March 11, 2018 Share Posted March 11, 2018 hey guys just wanted opinions on weather to use the 272 cams ive got in my 26/30 or run stock cams. as ive seen alot of setups making big power with stock cams. im running a 66mm borgwarner. haltech ecu. e85 . and a freshen up a6 bottom end , personally the idea of having stock cam and keeping the car quiter would be ideal. but if its going to cause issues for driveabiltiy with the larger turbo id rather not Link to comment https://www.sau.com.au/forums/topic/473521-rb26-stock-cams-vs-272-cams/ Share on other sites More sharing options...
GTSBoy Posted March 11, 2018 Share Posted March 11, 2018 sigh. What do you want to use the car for? What is the performance goal? Link to comment https://www.sau.com.au/forums/topic/473521-rb26-stock-cams-vs-272-cams/#findComment-7869823 Share on other sites More sharing options...
Skitzvk Posted March 11, 2018 Author Share Posted March 11, 2018 street and strip Link to comment https://www.sau.com.au/forums/topic/473521-rb26-stock-cams-vs-272-cams/#findComment-7869830 Share on other sites More sharing options...
Ben C34 Posted March 11, 2018 Share Posted March 11, 2018 If you like the idea of using stock cams, use them. Using stock cams won't cause drive ability issues.. Or use one stock and one 272 Link to comment https://www.sau.com.au/forums/topic/473521-rb26-stock-cams-vs-272-cams/#findComment-7869836 Share on other sites More sharing options...
Lithium Posted March 12, 2018 Share Posted March 12, 2018 I'd stick with stock or at least really mild cams - the likes of @Piggaz have had pretty good results from UE high lift low duration cams on fairly serious setups, they would be very easy to overlook and are very drivable. Link to comment https://www.sau.com.au/forums/topic/473521-rb26-stock-cams-vs-272-cams/#findComment-7870007 Share on other sites More sharing options...
