I'd be interested to know if a R33 exhaust would fit on a RS Four.  The front pipe & dump pipe look the same, but I haven't had a chance to compare the cat back section.
Also, my suspension in the Stagea is pretty firm for standard (they all look standard), handles very well for stock, would like to drop it about 25mm but that's about all.
J
Hi J, it is my understanding that an R33 4 door exhaust is pretty much the same. I am going to use the split dump and high flow cat off the R32 GTST. Then I will check and see how much I need to modify the R32 GSTST exhaust for it to fit as well. I might as well use it since it is getting a titanium exhaust with the new engine.
Our Stagea is far from firm, the spring rates may well be OK but it needs new shocks real bad. I am going to get a set of Koni Sports and move the circlips down a couple of notches. Once I work out which model shock it needs.
Then a pair of stabiliser bars and some adj caster, the steering is too light with not enouigh precision for my tastes. Should handle pretty good then. :(
https://www.sau.com.au/forums/topic/47354-hello/page/2/#findComment-960449
I have some Tein "S" springs coming from japan, they are made for the Staj with correct spring rates etc. I can get these for around $350.00. Expect around 4 week wait as they are ex Japan only. Exhausts (from what i have been told) are different to 33 2dr and 4dr, and different again from r34 stuff, if you find something that fits please let me know as i want an exh sooner rather than later.
Ken
https://www.sau.com.au/forums/topic/47354-hello/page/2/#findComment-960477
Thanks SK.  That's one thing I have noticed about the Stagea, and that the steering is very light !!  About the split dump pipe you've got, is that a CES dump/front pipe ??  What sort of $$ do they retail for and who sells them?
J
Nope, it's a Performance Metalcraft fabricated stainless steel work of art, that I promptly covered with exhaust wrap. I might get it ceramic coated before I put it in the Stagea, so I can show it off. :P
https://www.sau.com.au/forums/topic/47354-hello/page/2/#findComment-961064
Ken
Who is complying your car as CAM who did mine also build their own full exhaust system cat and muffler and had it emission tested so if an after maket one comes in you dont have to buy ex Nissan.
If it comes here in WA I have one.
https://www.sau.com.au/forums/topic/47354-hello/page/2/#findComment-961112
I have always wondered about this: can you adjust the power assist on the steering to weight it up a bit?
LW.
Not easily, you could try a larger pulley on the power steering pump or a smaller pulley on the crankshaft. That would slow down the pump, but you would have to experiment with the pulley sizes till you found one that added a bit of feel but didn't make parking too tough.
Better to add some caster, that serves three purposes. It adds more feel to the steering as more caster = more resistance to steering. Plus the car turns in better because of the extra caster. More caster also helps the car drive straight. So it's a win, win, win upgrade. :)
https://www.sau.com.au/forums/topic/47354-hello/page/2/#findComment-961266
SK: Interesting, interesting. Will be good to hear what your results are.
Although its a fine line, does the Stagea lack feedback as well as being overassisted, or just overassisted?
LW.
I prefer my cars to have a fair bit of feel, turn in instantly and track straight. The Stagea doesn't quite make it on any of these. Being 4wd and heavy, there is probably a bit of wear in the radius rod bushes not helping it either. For $100 or so it's a cheap fix. :)
https://www.sau.com.au/forums/topic/47354-hello/page/2/#findComment-961287
  • 1 month later...
Just thought I'd give a quick update, the car should be done sometime next week. Didn't have any real problems at all, worked out the "aftermarket suspension issue" as well as the aftermarket exhaust without any dramas or a hole in my wallet so now I'm eagerly awaiting the day I can actually drive the thing, because I really enjoyed driving it to the compliance workshop (unreg vehicle permit)!
https://www.sau.com.au/forums/topic/47354-hello/page/2/#findComment-998008
Got the car back today. I was going to get it registered too but the Department of Transport I went to (Sherwood) didn't want to register it for me and said I have to go to Greenslopes :D Ah well, I'll get it done tomorrow morning...
Also have to put my aftermarket exhaust and lowered HKS springs back in, then I'll be set!
https://www.sau.com.au/forums/topic/47354-hello/page/2/#findComment-1013940
    • Im not entirely sure exactly what or where its leaking from, he started to pull the boots to swap to my new tie rods + ends and it just vomited fluid, so he closed em up up, swapped the rod ends to the old rods and let me know so I can figure a solution out, im guessing its all origional as as I passed 103k miles earlier this year im sure its just in need of a full overhual/rebuild anyways.    If i could just yank it off and be good it wouldn't be an issue to ship it out and wait for the turnaround but the guy I work with doesnt really have space to keep my car for a week or two at a time, would rather drop it off and have a replacement ready to drop in
    • What do you mean by "seals"? Internal hydraulic seals (ie, is it leaking PS fluid?) or the rack boots that close the rack onto the tie-rods? Because the former is a rebuild, and the latter is trivial that you or any nearby mechanic could do. Dunno about the cowl. Just buy what you think is required and get anything else you find/break afterwards. Wing? Dunno. Don't like R33s enough to pay attention to them. Mirror glass is just glass (on the surface that you want to polish). Go for it.
    • Hello! Long time lurker, been using the forums to address concerns and questions from afar for a while but I've struggled to find some answers so I guess its about time I made an account and formally asked some more knowledgeable people, since finding local skyline owners is hard (and shops that are knowledgeable or trustworthy to work on 'rare' cars are non existent out where im at, as skylines are quite uncommon to find in the wild around here). So the main 3 questions I have, 1: Steering rack has blown seals, well.. they kind of hold but they are not sealed properly anymore and as my R33 is my DD, i cant exactly rip the rack out and send it off or attempt to fix myself. As most refurb ones are around $1,100 or more shipped, and I have other things I need to work on around the car, I was seeking clarification on whether an S15 rack will more or less bolt right in, and whether a common mechanic could do any other required work to get it to fit. I ask, as I've found a supplier than can sell a manufactured as oem one for around 400, if not I'll likely order a used one from Jacks JDM, and take a risk on the seals there. The second question i have is that im replacing the front wiper cowl and have planned to buy 4 new clips and a new center clip but wasnt sure if there were any other clips that would also need to get replaced while I was at it. Given im sure any that are there now will simply break when I remove the old cowl... Last thing would be a fairly straight forward question, i think. If I manage (strong if, finding one has proven to be a pain) to find a R33 GTR spoiler/wing will it require much modification to bolt to a S2 R33 GTST? I've read the bolt patterns dont match but otherwise would bolt in, only options I have found with much luck is China stuff on ebay and carbonetics, which has a nice $650 shipping fee... so if anyone has any pointers where a US chap could locate one that would be great Random side question as well, the mirrors as I understand are mirror glass, and as im planning to polish my windows from water spots and surface scratches, i was hopeful cerium oxide would be fine for them too, as my research points to, but clarification is always nice. Any pointers would be appreciated, and while I have scoured the internet for answers if I missed a prior post somewhere that may answer these directly please point me towards it, as i must have simply missed it. I have seen a post here or there that has mentioned it, but I usually get 50-50 answers, or half answers... I dont have a lot of fab experience or mechanic experience, outside of hydraulic and pneumatic stuff I did in the military and with how hard it is to source stuff in the US, id rather not wing it and hemmoraghe money lol. Thanks guys! Sorry for the monumental first post haha
    • Yep, there's a very minor drift left that happens a few seconds after letting go of the steering wheel, but not enough to bother me. Enjoying the car still!
    • Got you mate. Check your email!
