Hey all
So i recently bought a R34, originally it was a auto and the previous owner has done a manual conversion on it, drives around fine and what not. But it has come to my attention that the gearbox used is one out of a VL commodore ,well i think it is if someone can confirm the origin of the gearbox it would be appreciated (yes i checked previous threads from years ago but there was nothing confirming it). Also is it worth finding a proper R34 manual gearbox and swapping it out to future proof it ?
Gearbox Details
  • Has casted the following code - RP71C #2
  • 5 speed manual
only half decent photo of majority of the gearbox i have on hand at the moment
https://www.sau.com.au/forums/topic/473558-r34-gearbox-rp71c-2/
  • 1 year later...
Hemal, I’m in the exact same boat mate. I’ve tried researching it and have found that it’s fitted in r31,r32, r33, a31, z31. Not sure how true this is though as it seems anyone who has been asked this question all have different answers. I know it not much help but hopefully someone can clarify this for us.
On another note I’m assuming your trans crossmember doesn’t bolt up properly. Only two bolts where holding my up. I decided to cut and re-weld my. Here are some pictures of how it turned out if you where wondering. Hopefully this helps someone out there
It's easy to tell. The RB20DEt box is literally half the size of the RB25 and VLT gearbox. The 25DET and VLT box are almost the same thing, but I think the code on the VLT box was MX7.
And there's no need to go cutting and shutting the gearbox crossmember. There are 3 (actually 4) labelled A, B & C that all align differently and allow you to put pretty much any box in any chassis, for the most part, so long as you get the right one.
And last tip. Don't turn the boost up on the R34. It will wear the little box out quite quickly.
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
    • Me coming to check the thread to see if my manual boost controller was set up correct......
    • Ah yes but were you responsible? In the time I've had it (just before Christmas) I spun off the track twice and drove into things twice, so four separate incidents.. in two outings. Luckily I have a full OEM GTR front end to put on which is hopefully not a precursor for further, future, more expensive mistakes to come. It is some consolation that anyone who would want to buy my Altia bar would have to paint it anyway, the guards, too. (if they can get over the asymmetry). Hopefully over the weekend I will disassemble and see how badly things are bent. From what it looks like, the headlight has actually just been pushed back and bent the headlight support (which .. somehow... crushed the guard in). I guess the headlight plastic is strong stuff.
