Hi, Ive had my GTR for a long time now. Its stock apart from a catback exhaust and high flow cat. It came with a boost controller set to 1bar and had an Impul remap ecu.
The first thing i did was install power fc and newer model hks evc tuned to stock boost for australian 98 vpower.
My main question is since I like the car in standard form and dont drive it except in my estate to keep it running once a week. Would the stock ecu be a better option with the factory tune and safety features?
Are there any options for a remap? Or should i stick to the power fc and if i do, would it be wise to do a tune and dyno run since its been unchanged for over 5 years.
Any advice would be appreciated.
-John
https://www.sau.com.au/forums/topic/473572-bnr34-oem-ecu-or-power-fc/
5 hours ago, KiwiRS4T said:
If you know a good tuner who knows PFC just get a safe tune. The Impul ecu was tuned in Japan for Japanese fuel - your PFC can be tuned to match the fuel you are buying .
1 hour ago, r32-25t said:
Leave it alone cause with your current power fc the car is tuned for the fuel it is using, Nissan tune these to suit the high octane Japanese fuel and engines tend to die over here because of it
Yes i did install the fc as soon as i got the car. I used octane booster and drove gently to be safe while i waited for the date of the tune.
I asked the tuner to run the car safe and i always watch the knock.
Main thing id like to know is will the power fc current tune (since it was performed over 5 years ago) be optimal after years and maybe 6k kms?
And if i put a stock ecu in, how good were they; can they run optimally for the small modifications like an aftermarket exhaust and the subsequent mild increase in boost. Things like knock retard and closed loop?
Thanks for the replies so far!
There is no reason for the car to be retuned unless you where never happy with the tune done.
I wouldn't go back to a stock untuned ecu. For what you're doing with your car, the power fc is sufficient and although they dont have many of the modern ecu features, they do their job of running an rb very well. Cheers.
The power fc will be fine even after this time, the stock ecu will generally cause detonation even at mild modification level in Australia
Thanks guys, the power fc while older gen is still popular and seems to do the job fine. I just wanted to clarify about the oem ecu.
Seeing modern cars have flash tunes on the factory ecu: from the r35 to even a falcon xr6 turbo; i was curious if any company flash the older gen bnr series ecu with good results. Ive heard of nistune.
OK, let's be clear.  The Nissan ECUs of that era are (almost all) EEPROM based, so you can burn new EEPROMs and jam them in there.  But these days we just install a Nistune daughterboard which makes the ECU fully programmable.  Originally this was about as good as PowerFC + a little bit.  These days Nistune is much better even than that.
But you still don't need to be doing even that.
not on a r34 GTR ecu, no nistune support. i have a few jap ones here that are but its a big job and a pfc is cheaper as a tuned job.
    • If you are fine with China turbos, Maxpeedingrods makes a bolt on turbo. Ive had mine for two summers now and it seems to be holding up ok.
    • Howdy all Im in a little predicament and wondering what everyone’s thoughts are? I’ve had my long block rebuilt and am in the market for a turbo due to my old one having metal shavings from crank bearings (cause of rebuild) go throughout the turbos oil lines and there wheel has a little play. I’m not really aiming for any power, just trying to keep it as oem as possible, but I can’t find a turbo that’s built for the stock ecu or find something that would be a standard replacement. Anyone have any ideas or suggestions
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
