As the title suggests, does anyone know what components are available to increase the amount of negative camber in the rear of an NM35 Stagea? I'm slowly attempting to create a 'VIP'/'bippu' style build but I can't find a whole lot of parts to suit the NM35. Currently I have fitted Driftworks Front Upper Camber Arms to suit a 350z and have gotten to -6 deg happily but the rear is sitting at -5 deg with only a coilover installation. I do have 350z Rear Camber Arms but they seem to only be able to mount to adjust toe. At this stage its looking like most components will have to be fabricated.
https://www.sau.com.au/forums/topic/473581-stagea-m35-rear-camber/
Japan is always the best place to look first, to see whats available.
http://www.nagisa-auto.com/products/nissan/m35.html
Following that, I think you have to risk attempting to fit parts from Y34/F50 for the rear upper arms and the rear spring bucket lowering perch
http://www.nagisa-auto.com/products/nissan/y34_f50.html
You could also use the Z33/V35 rear spring delete for full coilover conversion and additional toe adjustment (to allow more camber from the camber arms).
Or you can weld on some thread for rear spring bucket adjustment
OR (and probably the easiest method) is to fit offset bushes to the rear upper arm.
(i think its these)
https://superpro.com.au/find/superpro-performance-handling-kit-for-a-superpro-suspension-parts-and-poly-bushings-for-nissan-350-z-z33-2003-2009-/productnr-SPF3321K/cid-999501121/vid-
https://superpro.com.au/find/superpro-performance-handling-kit-for-a-superpro-suspension-parts-and-poly-bushings-for-nissan-350-z-z33-2003-2009-/productnr-SPF3313XK/cid-999501121/vid-
Also, you said you have rear camber arms, but what about rear toe arms? its a must-have with camber arms because the camber arm adds just as much toe as it does camber....
I do have MCA Suspension 'Street Performance Series' coilovers installed all round dropping my ride height very low.
Since initially posting this thread I have seen a number of cars (none being stageas unfortunately) using an adjustable spring bucket as well as other components to adjust rear camber.
I may try offset bushes before attempting to order parts from Japan. Thank you for those links. I haven't been able to find any to suit from my own research.
I have said I have them but they aren't able to be installed for their intended purposes. They do, however, bolt in to replace the factory toe arm. All of the camber in the rear currently is achieved through lowering the car alone.
Attached is a photo of how the stagea sits currently.
That's a lot of camber from just lowering.
The rear end of Z33/V35/M35/G35/M45/Y34/F50 should all be very similar. Americans don't have any M35's so not many brands advertise for them or have test fitted to confirm.
I know, even I was impressed.
I think I may have to run the risk of fitting parts from Japan to get the desired camber. I'm not hugely keen on cutting and welding unless I absolutely must.
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
