Hey guys I'm having an issue with my monster ? ..
My r32 had a rb20de auto in it and the rb20de died. I sourced a cheap s2 rb25de auto from a stagea. Also got a s2 rb25de loom and ecu from an auto stagea as well (grey plug but non neo). Matted 25 to the auto box and put it in the car. I used the stagea loom and ecu and wired water temp, tachometer, fuel pump, ign and constant power where needed. Turn the key dash lights come on, fuel pump primes and turns off then I go to start and NOTHING! Starter motor doesn't even try to start. It's as if the inhibitor is stopping it (e.g in gear and not in park or neutral) Checked relay and it works fine. Checked fuses had one popped replaced it still nothing.  Checked starter and it seems fine also. So I'm Wondering where to start looking now as I've been at it for the last week with no progress ( I just want it running!!) Is there a way to bypass the auto system so starter will work? (Tried the manual conversion inhibitor trick that didn't work ). Would I need to make a wire from the neutral switch pin on the ecu to the neutral switch on the auto box to make it start?
Any help would be much appreciated. Also thinking of pulling out my ecu and engine loom (r33 s2 loom and ecu) that is in my r32 coupe as my coupe runs and starts 1st pop but it's manual so may run into the same issue.
Edited by Arh_Bee
https://www.sau.com.au/forums/topic/473588-stagea-rb25de-s2-into-r32-autobot/
