Hey guys I have a few questions as my sub-frame bushings don't have any clear instructions on what they want done with the caps.
I've found a few pictures of other members installing there's but a few guys did it different.
The rear I've seen installed 2 ways. 1) With a large cap on the very top and the small cap on the bottom. and 2) with only the small cap on the bottom. Can anyone please confirm how they installed theres?
Or like this with a cap on the top and a cap on the bottom.
xpost-12712-1175946848.jpg.pagespeed_ic.M3L7kC6BNk.thumb.jpg.d45f0192352795c49e8bc4428297d2c1.jpg
This is the front bushings (Closest to the engine bay) Do you simply install a large cap between the brace and the bushing cap? (Note this isn't tightened down thats why its not straight)
Edited by GarettH
https://www.sau.com.au/forums/topic/473599-r32-gtr-rear-subframe-bushings/
Are you talking about the actual subframe bushes (which are large, metal clad rubber things that need to be pressed in and out of the sockets in the subframe) or are you talking about some sort of pineapple rings that go on in addition to the bushes?  I ask, because what I see in your first photo appears to be pineapple rings, and your second photo appears to be "as Nissan intended" - ie, without pineapple rings, albeit the blue colour inside suggests that they're not factory type bushes.
I'm talking about the actual Nissan intended bushings not pineapples. The metal cups that squish the bushing were used on factory and I can't find if I'm suppose to use them on new bushing's.
Nissan bushings do not look like those big fat black things in your first photo.  A stock Nissan setup looks like the 2nd photo, with what looks like gaps, and those cups hanging about in the open.  If your bushes don't look like Nissan original, and appear to have integrated pineapple rings, then all bets are off when it comes to advice, unless someone here has used that type of bush before.  Where did you get them?  What manufacturer are they?
When using aftermarket bushes they all require different things to be done with the top caps, some need them removed and some need them reinstalled on top where Nissan put them in the first place, that 3rd photo is just straight out wrong
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
