Hey everyone, first off this is my first post on this forum. I don't know a whole heap about cars as of yet. I've always serviced and worked on my own old, and breaking down honda CRV, but it's time to move to a proper JDM performance car. I've got the money right now to purchase an R34 GTT, although all R34's for sale are all R34 GT's with swaps left right and center.
Well, I think they are. Correct me if I'm wrong, but an R34 GTT (4 door or coupe) will always have the 3 gauges above the center console right? So thats the first dead giveaway to tell if it's genuine GTT material. And second, something I noticed, is that the rear end is more boxy rather than round with the reverse lights under the park lights.
Anyway, I'm looking to purchase a GTT in Perth. What's the best option? Import or wait for a sale locally?
https://www.sau.com.au/forums/topic/473609-buying-an-r34-gtt-in-wa/
You can look up the VIN on http://gtr-registry.com/ to confirm.
If you're patient (e.g. willing to wait 1 year), you can get someone like iron chef to look for a nice GT-t.
But, there should be enough R34s floating around, you'll have to be patient either way.
What about buying interstate? You could find a nice, close-to-standard-as-possible one with import papers.
Correct, the gauges are a pretty quick way to see if it's a GT-T or not, however this is also pretty easy for someone to swap into a GT.
The second bits are not as easy, the GT-T also have fork type rear shocks like the R33 GT-R and bigger brakes than the GT model but I'd just check the VIN as mentioned above.
In terms of the tail lights, the 4 door R34 have a different tail light boot and rear bar design to the 2 door. GT/GT-T doesn't matter in this regard.
Not all GTT's have the triple gauge cluster – mine came with the Japan-only Xanavi satnav with the popup lid.
A full GT to GTT swap is quite intensive to do. Look for things like brakes and BMC (GTT units are larger), rear shocks like Jordy stated, also from memory GT's don't come with a rear swaybar stock.
If you want a solid factory GTT 4door buy mine, all you need is a tilt tray for freight :)
  • 3 weeks later...
Ended up picking on up on Saturday locally. Pretty damn stock to say it's a 20 year old car. Just double checked the Japanese model number under the bonnet, and yep I picked up a genuine GTT. The seller did go through that with me on purchase though, I just had no idea that you could check that. Very very happy with the R34, such a nice car to drive, and that turbo spool gets me every time.
    • It's kind of interesting - They definitely do builds that split the difference between what they like and what will generate views and engagement. The NC Platform always surprises everyone in a good way, in an uncomfortably good way some may say. They could throw a LS in there and arguably have the best (and best performing) car of the entire stable. But that isn't necessarily what draws views, because people viewing don't want to accept the vegetables of a LS NC MX5 being a superior vehicle in every way (including fun) than a RB26 240Z. This is also why there's not a lot of content about the GR Yaris (on the web in general). They're too good, yet 'only a Yaris' The community doesn't want certain cars to be as good as they are - to beat their hero cars, and I believe the NC MX5 is absolutely one of those cars.
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
