Hey everyone, first off this is my first post on this forum. I don't know a whole heap about cars as of yet. I've always serviced and worked on my own old, and breaking down honda CRV, but it's time to move to a proper JDM performance car. I've got the money right now to purchase an R34 GTT, although all R34's for sale are all R34 GT's with swaps left right and center.
Well, I think they are. Correct me if I'm wrong, but an R34 GTT (4 door or coupe) will always have the 3 gauges above the center console right? So thats the first dead giveaway to tell if it's genuine GTT material. And second, something I noticed, is that the rear end is more boxy rather than round with the reverse lights under the park lights.
Anyway, I'm looking to purchase a GTT in Perth. What's the best option? Import or wait for a sale locally?
https://www.sau.com.au/forums/topic/473609-buying-an-r34-gtt-in-wa/
You can look up the VIN on http://gtr-registry.com/ to confirm.
If you're patient (e.g. willing to wait 1 year), you can get someone like iron chef to look for a nice GT-t.
But, there should be enough R34s floating around, you'll have to be patient either way.
What about buying interstate? You could find a nice, close-to-standard-as-possible one with import papers.
Correct, the gauges are a pretty quick way to see if it's a GT-T or not, however this is also pretty easy for someone to swap into a GT.
The second bits are not as easy, the GT-T also have fork type rear shocks like the R33 GT-R and bigger brakes than the GT model but I'd just check the VIN as mentioned above.
In terms of the tail lights, the 4 door R34 have a different tail light boot and rear bar design to the 2 door. GT/GT-T doesn't matter in this regard.
Not all GTT's have the triple gauge cluster – mine came with the Japan-only Xanavi satnav with the popup lid.
A full GT to GTT swap is quite intensive to do. Look for things like brakes and BMC (GTT units are larger), rear shocks like Jordy stated, also from memory GT's don't come with a rear swaybar stock.
If you want a solid factory GTT 4door buy mine, all you need is a tilt tray for freight :)
  • 3 weeks later...
Ended up picking on up on Saturday locally. Pretty damn stock to say it's a 20 year old car. Just double checked the Japanese model number under the bonnet, and yep I picked up a genuine GTT. The seller did go through that with me on purchase though, I just had no idea that you could check that. Very very happy with the R34, such a nice car to drive, and that turbo spool gets me every time.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
    • 😜 hopefully we get this instead of a new R36 GTR due to recent financial problems at Nissan. Nismo to sell a complete kit with RB26 and driveline. All starts making sense (ok maybe not) once the Nissan Leaf's (Leaves?) with stuffed EV motors/batteries hit the market cheap
    • Hi guys , have had allot of time for SAU and has helped me out heaps in the past so I thought I would give it a go , I have my QM1 white NUR for sale 1 of 156 examples built by Nissan. Serious personal messages please if interested and details will be provided , asking 500k
