Hey, about to send the car in for a tune within the next week or 2, and interested in what you guys think, number wise, what it could be capable of making in its current setup so I will list off the mods for you, can assume things not listed to be stock.
98 R33 GTST rb25det
Apexi power fc + hand controller
exedy heavy duty clutch
exedy lightened flywheel
forward facing plenum
race works fuel rail
turbosmart fpr 800 fuel regulator
Denso 550cc injectors
walbro 255 fuel pump
yellow jacket coil packs
NGK BCPR7ES spark plugs (0.8mm)
exhaust system 3 inch, hi flow cat
front mount intercooler
op6 turbo (r34 GTT turbo) still low mount (looking to run 12 psi, or more, let me know what you think)
also if you want to throw in recommendations for what you would do with the car next would be mint for fresh ideas. No pun intended.
Thanks in advance
Edited by toldfield
update info
I'm going to start by guessing there's a 90% chance the yellow jacket coil packs will give out on the dyno and final tune deferred until replaced with splitfires, OEM or LS/Yaris/etc Conversion.
may need more detail though, target boost? boost controlled with? is it an r34 NEO or r33 rb25 or possibly even an rb20? how complete is the highflow exhaust? dump back? diameter? cat?
  • Haha 1
Nothing in that list is going to cause a power increase unless the Neo turbo is going on to an older 25 or onto a 20.  On a 25, the power added will be small.  On a 20, it will be good for a bit more.
My Neo, with essentially that complete list above (except the things that are useless, like the plenum and the big injectors) makes 191 believable rwkW on 12 psi.
Around 190 rwkw sounds about right. If i was you, id send that turbo to hypergear and get it highflowed (around $900) before your tune. Will then make around 260rwkw and you wont be paying for a 2nd tune after your sick of 190kw.
You may also want to gap the plugs down to around .65 to help those yellow jackets alive.
Later on you could put bigger injectors in and tune for e85 and make over 300rwkw.
Recommendations on what to do next depend on how much money you have and whether you want to go fast in a straight line or do other things safely.
Because you already have injectors and a fuel pump, following the above advice from admS15 is a good idea.  You will need to upgrade the airflow meter first though.
The first best thing is sticky tyres.  AD08R, RS3 or 4, KU36, or any of a bunch of others.
Everything else depends on the state of health of suspension and subframe bushes and so on.  You can spend 2x what the car is worth in about 15 minutes if you really want to.
Dude, my whole build thread is about doing things the wrong way (and I'm still correcting my faults) - so yeah, definitely do it right!
As mentioned, get your turbo High Flowed. I personally have got a Hypergear G3 profile on a 21U turbo, it picks up pretty quick, has no problems on 19psi and I'm not even at my final tune. For the record, I made 230rwkw on this turbo @ 14psi (couldn't hold boost at the time due to wastegate). If you're playing the long game, you can high flow your OP6 housing for more future power, or as ADM said, go 21U for quicker response. Not sure on your boost control plan?
As for the AFM, don't make my mistake and buy a cheapie. Get a genuine Bosch Z32 unit. Will cost $250-$320.
Ditch the Yellow Jackets. If you absolutely can't spend the money on Splitfires, then gap plugs down as mentioned.
Also ensure you've completed the relay mod on your fuel pump so you get full voltage and full juice.
If I was in your shoes right now, I'd be going:
  • High Flow Turbo
  • Decent EBC
  • Z32 AFM
  • Splitfires
  • Relay Mod
For approx $1800-$2200 in parts you'd then achieve 240-260rwkw.
Check out my build thread in the sig. I've gone through all of this already (as have many others on this forum).
  • High Flow Turbo
  • Decent EBC
  • Z32 AFM
  • Splitfires
  • Relay Mod
U received my pm? Lol ;p
    • Yeah, the latter. No diff should have a centre replaced without checking clearances because its unlikely to be the same as whatever came out. Not that that stops most people just checking a new centre in
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
