1980 Triumph TR7 FHC. No sunroof.
5sp manual, LSD, Koni struts and Whiteline bushes all round. Rust free, resprayed in Ford white, fresh windscreen seal, majority of the car has been undersealed.
Previous owner had the car for 20+ years, I was lucky to find the car before he sold it to the wreckers. I have put a lot of effort into getting the car on the road, but need to make room for other projects.
Stromberg carbs that have been rebuilt recently, twin choke. New choke cable, new accelerator cable. Front brakes have been rebuilt, rear drum cylinders replaced. 4x new tyres. Replaced fuel tank and fuel lines, which were rusted out. Electric temperature controlled fan, new trunk struts. All fluids replaced recently, barely gets driven.
Spares and replaced parts will come with the car (engine gasket kit, carbs kit etc)
Car is unregistered and will not come with the roadworthy.
Located in Rowville, Vic.
Price $4,500 for SAU members.
Seller details
  • Like 4
https://www.sau.com.au/forums/topic/473631-1980-triumph-tr7/
  • 1 month later...
  • 4 months later...
Dam! way to late Lol... been on the hunt for one, seen a few but have been let downs.. All seem to be out of victoria besides your one!
thanks for getting back to me
Yeah people want one and they want one local but I received lots of offers below $3k.
Keep an eye on the classifieds of Triumph Car Club Victoria. Some nice stuff pops up there, not many TR7s though
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
