yeah i am sure its the turbo spooling although, its not like usual, like i have the usually loud sucking sound from the pod, although now i can hear a slight whistle also. only just started happening, kinda sounds electronic in a way. and i can still hear it even when my engine is warm.
https://www.sau.com.au/forums/topic/47365-turbo-whistling/#findComment-957256
I had an odd whistle/hissing sound in my car. Took the heat shield off to investigate & found that only 2 of the 4 bolts holdin the turbo to the exhaust manifold were there! Found 1 on the chassis rail
Fixed this up & the whistle/hissing sound stopped, leaving just the sweet sound of spool up :(
https://www.sau.com.au/forums/topic/47365-turbo-whistling/#findComment-957288
When i blew my old stock turbo a while back, it made a VERY LOUD whistle sound kinda like that of an electric motor but LOUD, engine would run, but car wasn't in a driveable condition, drove like 40km/hr up to 60km max hoping that the rest of the turbo wouldn't fall apart and go into the engine..
anywayz. get it checked my friend if its not performing like it normally does,
my 2c
https://www.sau.com.au/forums/topic/47365-turbo-whistling/#findComment-957295
huh?? it interferes with the radio?? maybe its just the whining in the cables of the stereo or whateva that whinning sound is, most people get it when they have put a stereo in their cars if you know what i am referring too.
Boy it must be fairly loud to here it over the pod though as pods suck very loudly, i guess if your worried you could get a mecahnic to check over things for you to be on the safe side
https://www.sau.com.au/forums/topic/47365-turbo-whistling/#findComment-957301
Should be fine. just don't want to hear the turbo spinning when you've turned the engine off. :(
Yes you do! Helloooooo super smooth BB :)
Anyways.
Our skyline makes a noise like a rusty gate opening (but urm quieter?) if you let it slowly come off boost. Just at the point where I assume the turbo is starting to slow down again you hear it. Car still makes 1bar (1.2bar on occasion, oops, yay AVCR and its super non-spiking properties) and performs well though.
https://www.sau.com.au/forums/topic/47365-turbo-whistling/#findComment-957354
i think i know what you mean and i have the same noise. i installed a catch can on the inlet manifold and the afm pipes and mounted them on the fire wall and the sound is much more audible through the car now. not too sure what it is, maybe the PCV valve opening and closing?
-rb25
https://www.sau.com.au/forums/topic/47365-turbo-whistling/#findComment-957813
i can hear my turbo spinning when its cold in the mornings (when im trying to keep it off boost while it warms up, sometimes it creeps onto boost and i can hear them spinning heh)
I got the same thing, till it heads up then is normal spoolin noise. But i got 2 bolts that hold the the exhaust manifold to the head missing (dunno how) but she still spool up.
my 2c
https://www.sau.com.au/forums/topic/47365-turbo-whistling/#findComment-957976
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
