Short story long:
Went out to fuel up the night before I was due to go to Phillip Island, Labour Day weekend. Car wouldn't start at servo, discovered missing top starter motor bolt and almost missing lower starter motor bolt :huh:. Managed to get lower bolt back in, starter worked.
Drove to PI, drove home, everything fine. A week later, I removed the lower bolt so I could be sure I got the correct size replacement, got 2 new bolts for starter motor, fitted them (after basically removing everything from the engine bay :mad:). Went to start the car (on a jump), just spins over - absolutely no sign of wanting to fire.
I have spark. Pretty sure I have fuel (not confident of fuel pressure though). Don't know about compression (although don't know why it would suddenly disappear). Replaced fuel filter. Pretty sure I haven't disturbed any of the air hoses under the manifold (but how do you tell on these MFs).
Any help / guidance appreciated.
Engine is RB25DET, running off a Wolf 3D4+ ECU. Has basically been running fine since installed - this is the first real problem of this nature.
https://www.sau.com.au/forums/topic/473666-engine-wont-fire/
not clear...is the engine actually turning over?  Or just the starter motor?  Cos there is a jump lead from the motor to the solenoid - if the solenoid isn't getting power then the starter will not engage, will spin all day long but not engage.
Well, I'm stumped.
Got a compression tester and pressure gauge. I've got 44psi fuel pressure while cranking. Initial (cold) crank gives around 100psi across all cylinders, and final compression 135 / 125 / 130 / 127 / 130 / 130 (note: engine has forged pistons, so presumably will be a bit low on a cold crank). Engine can develop oil pressure during cranking.
According to the Wolf:
     Cranking speed is around 220rpm, cranking volts 11V (Wolf handset).
      Injectors have power, coils are firing, input trigger is firing (ECU lights)
Any suggestions as to where to look next. Anyone available in W Subs Melbourne to give me a hand.
Are your pistons wet from the fuel?  I know you have 44psi, but is it getting to the injectors?  If so then it has to be in the timing somehow.
You need fuel, air, and spark...you say you have all three...so then its timing.  You didn't remove the blocks earth strap did you?
  • 3 weeks later...
You can all stop looking for a solution.
When I initially installed the Wolf, I set up a little fuse box to protect things like injectors and coils. While I was installing the new bolts to the starter motor, I've accidentally removed a cable from that fuse box - so there was no power to the injectors.
  • Like 2
  • Haha 1
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
