Hey folks,
Have any of you guys used one of the headliner repair guys in Sydney?
The headliner in my BMW is knackered and my attempts to glue it up are not only failing but making matters worst because the glue makes the liner heavier.
Looks like some places will replace foam and liner for under $200 which seems like a good deal.
https://www.sau.com.au/forums/topic/473673-headliner-repair/
17 minutes ago, niZmO_Man said:
You're a BMW owner, you can afford it :P
Just give it a go yourself if you have time.
Yep, I reckon I will. I'll do all pillars too.
I'm just worried about it being a problem again in future. Maybe I'll just carbon wrap them. :D
So, I could quite easily switch to black too. Then I could just plastidip my trim (handles, light surrounds etc).
https://www.ebay.com.au/itm/Black-Car-Roof-Lining-Headliner-Upholstery-Foam-Headlining-Fabric-1-51M-x-2-2M/222578662525?hash=item33d2b8dc7d:g:rjkAAOSwvvBapKFt
38 minutes ago, Sinista32 said:
Christian have you tried these guys http://repairbull.com.au/Roof Lining Sydney.html
Advert on this site :)
Seems they  quote
Yeah they are one of the quotes. $540. :O
So I just pulled out and put back in (for rattles in the damn sunroof) the headliner of an E61 Wagon. (Slightly older than yours of course).
They're pretty straight forward to do (assuming you like allen keys and Torx). If you find a cheap headliner as a replacement that suits your car, give that a go. Just remember that there will be airbags everywhere. The cool part is once you have removed the trims from the pillars, there are just some clips that need pointy nose pliers to get the lining out. It took me a while (about 4 hours in total, over two days, so bank on using a half day and you won't go wrong).
For me, I found a bunch of clips that had snapped an the sunroof motor bracket was loose. Removed busted items, tightened bracket, no more rattles! I think someone may have replaced the sunroof motor before me, only they forgot to screw it in properly.
Thanks @Steve85 I watched a bunch of videos on Youtube and have decided to give it a go myself also.
I think besides getting the headliner in/out of the damn car the rest will be straight forward. I'm looking forward to giving it a go and even more looking forward to having a black interior.
That said, my wife reckons having black headliner and pillars will be a bit dark and heavy in the car. What do you think? I reckon it'll look fantastic.
Good idea about buying another liner. I could trim that one and then swap them.
  • Like 1
I just used that mob to redo the headlining on my mk5 golf hatchback. Really impressed with the quality of their work and the quality of the (black) material they used.
Bit surprised at the price though, I only paid $350...
  • Like 1
On 13/04/2018 at 4:27 PM, Jordy32 said:
My friend re-trimmed his R32 GTS-T Roof with a black fabric, it looks really nice.
In saying that, the grey skyline fabric gets pretty gross which makes improving on that pretty easy but I think the black looks really good.
Thats another reason for me wanting the black, light headliners and pillars get so grubby and you wont notice on the black.
Is it 3 or 5 door? My car is 4 door with a sunroof.
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
    • STOP GOOGLING FAB9 MAKE BORG WARNER EFR KITS FOR THE NC. THEY PACKAGE AN EFR 6758. DO NOTHING ELSE. CAPS INTENTIONAL. THE BEST RESPONSIVE SETUP EXISTS FOR YOUR CAR, AND HAS BEEN PROVEN FOR QUITE SOME TIME NOW. IN B4 "BUT I WANT EVEN MORE RESPONSE, IN A SIMPLER, MORE RELIABLE PACKAGE" WHICH IS A LS.
