14 hours ago, NEO25T said:
Looks good would be interested to hear the specs of the motor
Thanks man, off the top off my head
-Forged internals
-Spool conrods with arp bolts, spool oil pump gears
-Cometic head gasket, arp head stud kit
-Machined block, head and crank, with aftermarket cams and gears, timing belt kit, water pump, welsh plugs,
-New aftermarket intercooler and alloy radiator, hose kit
-Mantic Heavy single clutch stage 5 (i think) and flywheel with arp bolts
-recondition r34 gtt NEO  transmission
-r33 gtr 2-piece tail shaft and drive shaft,  forgot what diff housing because we tried so many lolll,  but ill have to double check , it has z32 internals with new bearings
-New 6 boost manifold and inlet, 1300cc injectors, MTA GT35/40 turbo 0.63 R/H with and full 3inch custom exhaust
- New Link G4 EC, N1 oil pump, new fuel system with pumps and tanks
thats all i can think off the top of my head :)
  • 1 year later...
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
