Hey there guys.
I’ve purchased some rims for my R34 GTT and think I may have gone too aggressive on the fitment. The fronts are 18x9 18p which i imagine should be ok, But i got 18x10 18p for the rear.
Am I dreaming to fit a 255 tyre on those over the rear with stock guards? I’ve rolled the inner lips in but dont want to do a pump, and can’t do stretched tyres currently as I need to certify the wheels.
Am I going to be able to get these to fit full stop or am I dreaming?
Thanks
https://www.sau.com.au/forums/topic/473718-closed-r34-gtt-wheel-fitment/
Guest
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
