Hi
I have been reading a lot on international websites and SAU. But I have yet to come across a method that works with programming our remote on our 350gt.
So I would like to know if anyone in AU/NZ has managed to programme a key remote? There are programmers out there that do this for a living so I dont see how this is not achievable by ourselves. People from the USA seem to be able to programme their keys without any problem but I have not seen anyone here in AU/NZ that manage to do this ourselves.
Also one thing I am not so sure of as I dont have any numbers on my Nissan key, is the part number. Are they compatible with the KBRASTU15 replacement key that is so common on ebay? What is the frequency on our remote?
Thanks for hearing me out. Cheers.
https://www.sau.com.au/forums/topic/473721-nissan-remote-key-programming-how/
i think if you were to take that key number to a locksmith with the right equipment they would be able to cut the key according to the factory specs, even if you have a dud key fob(electronic bit) but the blade of the key is intact even if it's worn they would be able to cut the key to factory standards, then its just a matter of the programming sequence, I know the sequence in the attached file worked for my series 2 Stagea WGNC34, but I'm not sure about other later model stuff
Mine does enter the programming mode (doors unlocked) so I believe this method is still the same for my year. What I am getting to is that when I pressed the button on my new key fob my car does not respond. This is the same remote that the americans use which worked on theirs (all the videos I watched on youtube has  the flashing lights, not doors unlock) and I am now wondering if that particular remote would work on our japanese import cars.
Does anyone on here knows what frequency is our remote? As in V35 350gt. And the factory remotes FCC ID?
Sorry can't help you out any further, just got those instructions with the keys I purchased from ebay, and took 4or5 goes to get the timing /sequence right for them to work, you have to be spot on or it'll do half of the process  and have to start again.
Could also try trawling some of the US or European forums especially the UK ones, those guys ask squiliions of questions
  • 5 months later...
  • 4 years later...
Nissan vehicles are equipped with a specific type of key called a “smart key” or “intelligent key.” These keys do not require physical contact with the vehicle or manual programming. To program a new Nissan remote key, insert the key into the ignition and turn it to the “On” position. Push the brake pedal while pressing the “Lock” and “Unlock” buttons on the remote control simultaneously. Hold the buttons until the hazard lights flash twice, indicating the key has been successfully programmed. I hope that helps :)
@ttcw Not sure where you are located. If your in Sydney, I recently had to replace a broken/lost key fob for my 370GT. The guy I mentioned in my post linked below, was what I think is reasonably priced, and supplied the fobs (ie main plus a spare) and programmed them both on the spot using a portable tablet, with software specific for programming keys for multiple manufacturers.
Of course, give the DIY a try first to maybe save a few dollars.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
