Hi
I have been reading a lot on international websites and SAU. But I have yet to come across a method that works with programming our remote on our 350gt.
So I would like to know if anyone in AU/NZ has managed to programme a key remote? There are programmers out there that do this for a living so I dont see how this is not achievable by ourselves. People from the USA seem to be able to programme their keys without any problem but I have not seen anyone here in AU/NZ that manage to do this ourselves.
Also one thing I am not so sure of as I dont have any numbers on my Nissan key, is the part number. Are they compatible with the KBRASTU15 replacement key that is so common on ebay? What is the frequency on our remote?
Thanks for hearing me out. Cheers.
https://www.sau.com.au/forums/topic/473721-nissan-remote-key-programming-how/
i think if you were to take that key number to a locksmith with the right equipment they would be able to cut the key according to the factory specs, even if you have a dud key fob(electronic bit) but the blade of the key is intact even if it's worn they would be able to cut the key to factory standards, then its just a matter of the programming sequence, I know the sequence in the attached file worked for my series 2 Stagea WGNC34, but I'm not sure about other later model stuff
Mine does enter the programming mode (doors unlocked) so I believe this method is still the same for my year. What I am getting to is that when I pressed the button on my new key fob my car does not respond. This is the same remote that the americans use which worked on theirs (all the videos I watched on youtube has  the flashing lights, not doors unlock) and I am now wondering if that particular remote would work on our japanese import cars.
Does anyone on here knows what frequency is our remote? As in V35 350gt. And the factory remotes FCC ID?
Sorry can't help you out any further, just got those instructions with the keys I purchased from ebay, and took 4or5 goes to get the timing /sequence right for them to work, you have to be spot on or it'll do half of the process  and have to start again.
Could also try trawling some of the US or European forums especially the UK ones, those guys ask squiliions of questions
  • 5 months later...
  • 4 years later...
Nissan vehicles are equipped with a specific type of key called a “smart key” or “intelligent key.” These keys do not require physical contact with the vehicle or manual programming. To program a new Nissan remote key, insert the key into the ignition and turn it to the “On” position. Push the brake pedal while pressing the “Lock” and “Unlock” buttons on the remote control simultaneously. Hold the buttons until the hazard lights flash twice, indicating the key has been successfully programmed. I hope that helps :)
@ttcw Not sure where you are located. If your in Sydney, I recently had to replace a broken/lost key fob for my 370GT. The guy I mentioned in my post linked below, was what I think is reasonably priced, and supplied the fobs (ie main plus a spare) and programmed them both on the spot using a portable tablet, with software specific for programming keys for multiple manufacturers.
Of course, give the DIY a try first to maybe save a few dollars.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
