Just got some Recaro seat rails on the cheap for my car (stagea).
My question is: do all recaros seats use the same size rail? (and other brands respectively as well)
ie. if I have recaro rails can I safely go out and whack any recaro seat on it?
I'm looking at nabbing seats from an Evo X, unless anyone else has any good leads!
https://www.sau.com.au/forums/topic/473739-recaro-seat-rails-universal/
I put some Recaros from a Honda into my S1 Stagea and had to use something like this (plus some adapters IIRC):
https://www.trademe.co.nz/motors/car-parts-accessories/interior/seats/auction-1594498064.htm?rsqid=4fbaa7ac69a749ab8e8e28460544d919
I suspect you will have to source some special rails to fit EVO seats. Try to go to a wrecker and have a look at some to see what you are up  against.
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
