Hey Guys,
Selling our 370GT  sedan, as my wife wants something smaller and manual, and I barely drive it.
Its a 2010 type S (sports) model, being a 2010, that means the 7 speed auto, (with paddle shift). VQ37VHR. Basically the same engine/gearbox as an auto 370Z.
I carried out a JOC before I purchased, and it is a 4.5 grade import, imported early 2017, and first aus rego was march 17. Can supply VIN if you'd like to check for yourself.
96xxxkm currently.
It has the option front lip and rear spoiler, and is stock except for a Nismo cat back, and Nismo shock/spring combo.
Infinity G37 Grill and rear badges has been installed, this was carried out in japan, as the pics in the JOC report show the badges fitted
The car came with full japanese log books, the Nismo "certificates/documents" are still there also, as well as documentation for the front lip, etc. Small details, but I found the log books/nismo certs cool to look through, even though I can't read them :)
One small scrape on front lip, (10mmx5mm), right rear tail light has a small barely noticeable chip, interior has a couple of small marks, barely noticable.
Rego till August
Its a great car to drive, handles well, and is quite quick, but as above, the miso prefers manual and something a bit smaller.
I can take pics of log books, or any other areas, just PM me.
Located in Nowra/Wollongong.
Price: 20k negotiable.
Edited by CEF33Y
https://www.sau.com.au/forums/topic/473742-2010-370gt-sedan/
  • 1 year later...
  • 1 month later...
Yes still for sale.
KM now around 120k.
New pirelli tires fitted 5k ago.
Bremtec pads all round 5k ago.
Also has a set of HSD coilovers. Still have the nismo suspension.
Fairly Negotiable on price too :)
Edited by CEF33Y
  • 4 weeks later...
  • 3 weeks later...
  • 4 weeks later...
  • 3 weeks later...
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
