Hey Guys,
Selling our 370GT  sedan, as my wife wants something smaller and manual, and I barely drive it.
Its a 2010 type S (sports) model, being a 2010, that means the 7 speed auto, (with paddle shift). VQ37VHR. Basically the same engine/gearbox as an auto 370Z.
I carried out a JOC before I purchased, and it is a 4.5 grade import, imported early 2017, and first aus rego was march 17. Can supply VIN if you'd like to check for yourself.
96xxxkm currently.
It has the option front lip and rear spoiler, and is stock except for a Nismo cat back, and Nismo shock/spring combo.
Infinity G37 Grill and rear badges has been installed, this was carried out in japan, as the pics in the JOC report show the badges fitted
The car came with full japanese log books, the Nismo "certificates/documents" are still there also, as well as documentation for the front lip, etc. Small details, but I found the log books/nismo certs cool to look through, even though I can't read them :)
One small scrape on front lip, (10mmx5mm), right rear tail light has a small barely noticeable chip, interior has a couple of small marks, barely noticable.
Rego till August
Its a great car to drive, handles well, and is quite quick, but as above, the miso prefers manual and something a bit smaller.
I can take pics of log books, or any other areas, just PM me.
Located in Nowra/Wollongong.
Price: 20k negotiable.
Edited by CEF33Y
https://www.sau.com.au/forums/topic/473742-2010-370gt-sedan/
  • 1 year later...
  • 1 month later...
Yes still for sale.
KM now around 120k.
New pirelli tires fitted 5k ago.
Bremtec pads all round 5k ago.
Also has a set of HSD coilovers. Still have the nismo suspension.
Fairly Negotiable on price too :)
Edited by CEF33Y
  • 4 weeks later...
  • 3 weeks later...
  • 4 weeks later...
  • 3 weeks later...
    • Don't do it if your gearbox box has already having syncro issues. The short hifter will put a greater load on them. If you must I remember Nismo did a shorter shifter, with the top part being physically shorter and the part that went into the gearbox was the same as stock. In saying that I've had a C's short shifter (I think) in mine for many years, which was given to me as the previous owner was not sympathetic to the gearbox. Thus forwarned I was careful and had to modify my normal changing style. You have to be super accurate with your clutch and shifts
    • Well, after a week of daily driving and having to crawl out between the wheel and the side intrusion bars. I got myself a quick release setup. I went with an NRG short hub and Quick Release with some cute heart cutouts on the pull tabs. Nice and matchy matchy with the rest of the interior accents I have going on.  The only downside is the total stack height even with the short adapter is longer than the old HKB boss kit. Luckily I had some adjustment left on the column so move the wheel away.
    • stock shifter with new bushes, springs and cup will improve it. Gktech do all the bits. The opinion as the years have gone on is the redline is not great in old gearboxes.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
