So just done ffp on my neo (greddy style) along with the fuel rail so I bought a sard fpr it’s a knock off. Trying to set it a at 43psi without vacuum but it won’t raise or lower fuel pressure. It’s static at about 39psi ? I have it setup like so :
tank>filter>fuel rail>fpr>return to tank.
Anything i have missed or is it just a bad fpr? I know it’s a knockoff but it’s new and it should work?
Edited by r34.rory
Added pic
https://www.sau.com.au/forums/topic/473746-can%E2%80%99t-get-fpr-to-adjust/
What fuel pump do you have?
What size is the return line?
Is there any kinks in the return line?
What size is the outlet of the reg?
Knock off regs is just asking for trouble. It’s kind of important.
On 12/04/2018 at 12:19 PM, inmaniac said:
Shouldn't use a knock-off for something so important, such as an item related to fuel delivery.
Trust me.. I only speak from experience
Lol true.. I still have one fuel damper if that would even matter? the damper is about 3/4 inch after the return port on the fpr.
new fpr still not arrived so I went to have a look again.
11 hours ago, NEO25T said:
You havent got fuel going in the out port of the reg? Not sure if it would make a difference or not
Nah the outport is returning to tank. also tried another fpr and gauge and still can’t adjust either way !! wtf I’m f**king annoyed to say the least....
5 hours ago, KiwiRS4T said:
Replace the pump since you have one and eliminate that as a problem. If your new fpr still doesn't show 43 psi get an adapter for your stocker and use that.
yeah I think I will swap the pump out. if no success I will get the stock fpr and try a gauge on it.
Car was running fine before I changed the plenum. It’s sat for a couple months whilst doing so maybe the battery is weak I’ll check to voltage for the battery and the pump. What should the pump be getting do you know ?
Edited by r34.rory
7 hours ago, r34.rory said:
It adjusts down and needle doesn’t fluctuate. Gets to 3 bar and doesn’t get any higher and fluctuates. what’s a good brand fpr? Malpassi any good?
Nissan
Or if you want to spend more money  - Turbosmart or Tomei (but beware - lots of Tomei knock-offs around.
    • How f**ked am i? what would happen if i leave the magnet inside there?
    • I'll update you guys when i get home from work, im going to try to fish it out.  I just realized that i can't even drop the oil pan. The whole front diff and axles are connected to the oil pan... is it even possible to drop the oil pan without taking out the motor?
    • So recently at the track had experienced a loss of throttle after a period of WOT after installing the emtron ecu, recently did some logging to troubleshoot the issue and found the ECU was cutting due to a low oil pressure issue. Going over the log can see that while accelerating at 4k rpm will see 100 PSI of pressure and holding steady at that level until getting off the throttle which then after can see as low as 25 PSI at 3-4k rpm and will recover back to a normal level after that.   Wondering if anyone has an idea what could be the cause as it just feels abit strange and i dont feel like it could be a sensor issues just due to it clearly sitting at a good pressure until off throttle, in the attached can see a 3rd and 4th gear pull but can even perform great through 3 and 4 gears of WOT but still once off throttle and getting back on it will see pressure drop.
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
